0.6 HF SPEED vs STRUCTURAL profiles.
djcody
(@djcody)
Not sure if this is the right place for this, but here goes...
Trying to print a square for the end of my track saw track with my 0.6 mm HF nozzle on Core One with Printed Solid Jesse PETG.  I initially printed with HF 0.32 SPEED profile and got some terrible perimeters.  It looks like the machine was just going way faster than the heater/nozzle could keep up with.
Tried again with 0.32 STRUCTURAL profile and got much better results.
Should the default HF profiles have worked out of the box?  Or should I expect to have to do some fine-tuning to avoid under-heated perimeters like I saw?
If I have the time, I'll set up a test with a smaller model and punch through all the 0.6 HF profiles and see if any others don't produce an expected finish.
Respondido : 05/05/2025 8:18 pm
RE: 0.6 HF SPEED vs STRUCTURAL profiles.
Frankly, I don't even know why the speed profiles exist… Isn't everyone interested in getting the best possible output? And we're not talking days or even hours of difference for most prints.
Respondido : 06/05/2025 11:58 am
Biomech
(@biomech)
Posted by: @djcody
So bump up the nozzle temperature. And it will catch up. Non HF filaments may need more temperature to melt properly at high flows.
Respondido : 06/05/2025 12:51 pm
davidr91
(@davidr91)
This is actually the same kind of problem I'm having here
Do the missing/bad extrusions cause the printer to make a noise when it misses?
What I found is that the speed profile caused the issue to begin with, but then I started having the same issue with structural too (on stock nozzle even). Would be interested to see what your results are if you try this test model I use to repro it on my printer: https://www.printables.com/model/1285853-fast-continuous-extrusion-test
Respondido : 06/05/2025 1:12 pm
LarGriff
(@largriff)
If you have a non-highflow nozzle, you might try it.  With non-HF settings, of course.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Respondido : 06/05/2025 1:33 pm
Ratlet
(@ratlet)
Is there a downside to using the non hiflo settings with the hiflo nozzle?
Respondido : 07/05/2025 8:26 pm
Biomech
(@biomech)
Yes. It may clog the nozzle because of low temperature. HF printer profiles comes with different filament profiles, which typically has higher printing temperature.
Respondido : 07/05/2025 8:50 pm
