Yet another layershift problem...
Rigge1988
(@rigge1988)
Trying to print a plate 150x70x6mm.
The layershift happened at layer 6. On the first layer without solid infill.
I have unticked "avoid crossing perimeters" and set "ensure shell thickness" to "disabled".
I heard the printer make a "thud" sound, like it was moving really fast and came to a sudden stop mid movement. The motor(s) didn't squeal this time.
Went to check it, and yes, layershift.
If anyone wants to investigate I will attach the project file.
Hardware-wise I checked belt tension, it's what I'd say is okay. Unlike first time around when "ensure shell thickness" was causing a layershift the belts stayed relatively in tune. From 92/98 to 91/100. Which I believe can be caused by something stupid like ambient temp.
Anyway. Before try no.2 I adjusted them back to 92/98.
Since Im having problems uploading a picture here I will simply explain. The layershift happened like I said at layer 6. It successfully did the perimeters around the right hole but the left hole was put down x, +8.80 y, +8.80 mm wrong. So whatever happened, happened between the holes. And the only thing I can suspect there is the wiping procedure. Unless a poltergeist put his curious finger in the belt.
Napsal : 16/08/2025 1:39 pm
Rigge1988
(@rigge1988)
RE: Yet another layershift problem...
I just simply reprinted and the print was successful. Which suggest there was something with software/firmware.
Napsal : 18/08/2025 8:22 pm
That size, and the thud, make warping the first suspect.
Pictures or part files would greatly help with diagnosis.
Napsal : 18/08/2025 10:03 pm
Rigge1988
(@rigge1988)
Posted by: @diem
No warp. Like I said, it happened on the model between 2 holes on either side.
I thought I had attached the project file. Guess it didn't work.
https://imgur.com/J4h7WdB
Napsal : 19/08/2025 2:47 pm
Please show us the underside of that failed print.
Napsal : 19/08/2025 3:34 pm
Rigge1988
(@rigge1988)
Posted by: @diem
Im afraid I threw it in the garbage bag I brought out yesterday. But this is not an interrogation. You will just have to simply believe me. I am not new in this game of 3D printers. The thud-sound it made sounded more like/very similar to a machine boundary/end point thud rather than a collision-with-print thud.
Cornflakio,
Napsal : 19/08/2025 3:38 pm
By the look of it it crashed into the poorly printed surround of the hole on the left.  You might have a point of poor adhesion on the plate beneath this or a draft might have messed with the cooling from that quarter.  You might benefit from expanding the infill/perimeters overlap (expert mode) but it may create more problems than it fixes.
Napsal : 19/08/2025 11:48 pm
