WiFi stopped working
Rik
 Rik
(@rik)
Hi all,
Out of the box the WiFi worked well, I had no issues.
Until recently the WiFi connection became unreliable, after booting up the printer half the time it wouldn't connect.
This morning it worked fine, this evening it fully doesn't want to connect. Even after several restarts and resets.
The machine has not been changed or altered in any way physically, the only change I can think of is the recent firmware update.
When I run the WiFi wizard, and scan for networks, it does not show any networks. Not mine, not those of the neighbours.
All other WiFi devices work fine.
I've resorted to loading up prints via USB.
Any suggestions?
Posted : 14/12/2025 9:08 pm
Try resetting your network settings. If you are running the 6.4.0 firmware, goto Settings -> System -> Factory Reset -> Ownership Transfer -> Execute Factory Reset
This will reset your network settings only. Then run the Wi-Fi setup procedure after the printer restarts.
Posted : 15/12/2025 6:32 am
