Where to decrease the sensitivity in the tune menu?
I can't print because it detects a crash when the bed moves up towards the print head. The menu says to decrease sensitivity in the tune menu. I can't find a sensitivity setting. Is it missing?
This topic was modified před 7 months by Salzwiese
Napsal : 13/08/2025 7:24 pm
RE: Where to decrease the sensitivity in the tune menu?
If you're getting crashes while trying to home the "Z" axis, it's likely a loadcell issue.
Check the loadcell reading on the sensors menu.
It's also possible you're running into the issue with the heater current disrupting the loadcell readings. See https://forum.prusa3d.com/forum/prusa-core-one-hardware-firmware-and-software-help/crash-detected-6/ for a thread discussing how to work around this.
Napsal : 14/08/2025 3:41 pm
