Page 64 / 65
Chris Hill
(@chris-hill)
Posted by: @gb160
'While the 3D printing community has identified several potential sources for VFAs, including motor resonance and belt mechanics, our deep analysis of the affected community printers pointed overwhelmingly toward improper belt tension on the CORE One.'
Again - read between the lines.  He didn't say the community was wrong about motor resonance and belt mechanics.  He's simply saying that the printers they've had back had improper belt tension.
Publié : 03/09/2025 9:45 am
GBMaryland
(@gbmaryland)
Posted by: @gb160
Posted by: @gbmaryland
Well I just printed up the core one VFA test print… and I compared it to a prior one that I did and it’s definitely a little bit better. There is absolutely one speed range that utterly sucks… otherwise it’s definitely better.
I used the “balanced” .20mm layering in a .4 mm HF nozzle.
I suppose real question does the G code supersede any of the features they put in the beta version of the slicer?
If you've just used old gcode. it's not going to use any of the new features/profiles recently added in the beta....Gcode is already sliced.
The slicer makes the gcode.
So no surprise you haven't seen any changes.
What did make me chuckle is reddit is full of posts about how the new settings/profile have solved VFAs, most of the attached pictures are either matte or filled filaments 😂
I think what Josef said about looking for them with VFA tests is right, all 3d printers (especially Core XY) will show them, its just physics...the task is reducing them to an acceptable level. So maybe the VFA tests are always going to show them to some level or another.
Real world tests are what its all about, so maybe printing that gridfinity bin that @baztm linked to earlier would be a fairer test...plus it means not wasting hours/filament on stuff that's ultimately going to end up the bin.
no, in my case I took the 3MF and re-sliced it… I noted that the G codes for increasing the speed stayed in the overall project but otherwise it got sliced by the new slicer. My comment was more related to wondering, if aside from speed changes the original creator of the VFA test for core one had done anything else other than change speeds. Honestly, there are very clear bands where it is obvious that the printer doesn’t like that speed with respect to VFA. I will say that it’s  better than the last one I ran base purely on G code, as opposed to sliced by myself. However, to quantify that would take some extra work on my part.
Publié : 03/09/2025 9:54 am
Rainer
(@rainer-2)
I agree that the other major change, to the ringing-type artefacts, should hopefully apply to all printers, including my 1.5mm setup.
Not only that, but the intelligent slowing down of the cooling time affects all profiles and creates even surfaces.
The speeds are easy for you to adjust. But if you mostly print in structural profiles anyway, it fits.
The important thing is the result. And if it turns out that I'm happy with the improvements, I'll leave it that way.
If I had converted to 1.5, I wouldn't go to the trouble of rebuilding.
As long as there are no other recognizable disadvantages.
Publié : 03/09/2025 10:00 am
2 personnes ont aimé
gb160
(@gb160)
Posted by: @chris-hill
Posted by: @gb160
Again - read between the linesHe didn't say the community was wrong about motor resonance and belt mechanics.  He's simply saying that the printers they've had back had improper belt tension.
I'll say the same to you mate, that's exactly what he's inferring imo...he's just being diplomatic about it.
Publié : 03/09/2025 10:09 am
gb160
(@gb160)
I honestly don't know if re-slicing the 3mf in the beta with the new profile/settings enabled overrides the speed changes made by the creator of the test mate.
Posted by: @gb160
Publié : 03/09/2025 10:16 am
Chris Hill
(@chris-hill)
Posted by: @gb160
Haha - ok, I'm happy to agree to disagree.  He can imply all he likes, but if he wanted to say that those things don't have an effect, he could have said so specifically.  He didn't.  He wanted you to believe that belt tuning is all you need, without going on record to say that motor resonance and belt mechanics don't have an effect.
Publié : 03/09/2025 10:23 am
GBMaryland
(@gbmaryland)
Posted by: @gb160
to be fair… A lot of problems I’ve seen have been related to people building the machines incorrectly (possibly helped by The sometimes very difficult to understand instructions).
however it’s also pretty clear that even with a flawlessly working printer, you get VFA!
Publié : 03/09/2025 10:39 am
baztm
(@baztm)
People should stop using the VFA test tower. I found it was not representative of what I was seeing on real prints. Stick to real models and slicing
Publié : 03/09/2025 10:42 am
3 personnes ont aimé
Cédric
(@cedric)
Yeah i did some test pieces and the results are that well correlating with the VFA tower.
Just for fun i did Input shaper, phase stepping and new 2.9.3 slicer to see if there would be any diffference compared to how it was before, just put together by me, printed some test cubes with a shiny filament in speed and structural (no balanced for the non high flow nozzle 🙁 ) and there were definitely visible VFAs there. Though my printer has always had pretty mild VFAs compared to others in the VFA tower. Will test some more realistic pieces and see how it does. Contrary to the prusa post i found my printer very insensitive to belt tension levels, sloppy or tight to spec gave me the same results pretty much.
Publié : 03/09/2025 10:53 am
1 personnes ont aimé
Rainer
(@rainer-2)
Posted by: @baztm
The VFA test is only useful to determine the best areas for speed.
Or to evaluate the effects of hardware changes.
On the subject of what Josef may or may not have said. Ultimately, only he knows. We tend to interpret what corresponds to our own opinion.
Ultimately, if what comes out is good, he is right.
But maybe it could be even better?
The future will tell.
Publié : 03/09/2025 11:00 am
Cédric
(@cedric)
Posted by: @cedric
Its supposed to say "not well correlating" in regards to the VFA tower, it looked quite different in actual prints, including how the pattern looked like.
Publié : 03/09/2025 11:27 am
TeamD3dp
(@teamd3dp)
Let's just see how confident (stubborn?) Prusa is in their software fixes when they release their next new printer. I maintain that they would be silly to use GT2 belts.  From discussions here already, it seems that many agree that VFAs will still be present.  What this means is that if they stick with GT2 belts for future printers and continue to have worse VFA's than Bambu, Qidi, and everyone else who changed spec to GT1.5 belts, it won't be good for them.
There very well may be specific build plate size/belt run correlations for where the various belt pitches resonate better/worse.  Prusa has a different build plate size than most others, and it could be that the resonances of a GT2 belt are just a bit more reinforced due to the specific X and Y idler-idler distances on this printer at specific speeds.  I can guarantee you that there are core one's at Prusa HQ that are testing GT1.5 belts, and if the results indicated no improvement it would have been stated clearly in these VFA posts.
-J
Publié : 03/09/2025 1:04 pm
GBMaryland
(@gbmaryland)
Posted by: @baztm
I really did it purely to see if the updated slicer using the 3M F file would actually any sort of different results.
I will say that the new slicer when slicing a real job actually screwed up the top layer on the print job… So I’m not entirely sure the new slicer is ready for prime time
Publié : 03/09/2025 1:13 pm
Ratlet
(@ratlet)
Ive got a print going after unblocking my hf nozzle (ran some cleaning filament through it and then some pla on a nylon heat).
Not op's box, but a gridfinity container all the same.  Ive printed loads of gridfinity boxes in different filaments so should give a good idea of the new slicer settings effect.
Publié : 04/09/2025 7:38 pm
adaddison
(@adaddison)
Membre
Question, for those of you that upgraded to GT1.5 belts, what belt tension are you running on them?
Publié : 16/09/2025 4:34 am
TeamD3dp
(@teamd3dp)
Interesting discovery for me today while running a PA calibration on our Qidi Q2 at work...I see prominent belt ripple along the pure X movements.  🤔.   Granted this isn't a VFA test, but so far I'd seen only very smooth walls from this printer.
-J
Publié : 18/09/2025 10:22 pm
Jondoe
(@jondoe)
Posted by: @teamd3dp
-J
I think Qidi use speed exclusion zones in their slicer profiles to avoid belt ripple problem speeds - the PA test might have overridden that?
Publié : 18/09/2025 10:47 pm
TeamD3dp
(@teamd3dp)
That wouldn't surprise me.  I was calibrating some FR PC/ABS, and had slowed the MVF to 6, to try and improve quality.  It had printed the ezPC beautifully, but needed some work with the FR blend.  If I'm able to get the fan settings tuned and get the corner details looking right, I'll speed it back up.  It does support the claim that a big piece of this belt ripple problem is connected to speed.
-J
Publié : 19/09/2025 1:31 am
xzess
(@xzess)
Membre
Posted by: @adaddison
Between 80Hz and 85Hz on both belt with the old method.
Works like a Charm. Almost no VFA.
Publié : 19/09/2025 8:27 am
gringo
(@gringo)
What changes need to be made to the firmware and how?
Publié : 22/09/2025 7:04 am
Page 64 / 65
