Update Firmware does not work!
Capodelosplasticos
(@capodelosplasticos)
Hello everyone!
I upgraded my MK4s to CoreOne over the past few days.
Now I want to update the firmware, but it doesn't work.
The "Incorrect hardware" error message appears on the display.
I gave the MK4s the latest firmware (6.4.0) before upgrading. This can be seen in the attached photo 1347!
I tried to start with the button pressed and without pressing the button, the same error message always appears!
The USB stick is freshly formatted and only the latest firmware for the CoreOne is on it!
What can I do?
Can someone help?
Thank you in advance!!
Napsal : 07/03/2026 2:00 pm
Cary
 Cary
(@cary-2)
RE: Update Firmware does not work!
I went through this on Thursday. You have to disconnect the extension board and the door sensor switch. Flash the printer with the MK4s 6.2.3 firmware. After you get back to the setup menu, select your language and skip all of the calibrations. Now do a hard factory reset from the menu. Now you can hook up the extension board and the door switch. Finally you can flash the printer with the latest core one firmware. I suggested they put the Firmware version 6.2.3 info in the instructions. I guess it is not common but happens often enough. Hope this helps
Napsal : 07/03/2026 2:38 pm
Yes, that happened to me. If I remember in my case, it was actually that my Prusa USB stick was bad. I think you actually do need 6.4.0 installed first and not 6.2.3. You can also push the rotary button in while it's booting up (when you see the Prusa Logo) and it will force load the firmware.
Napsal : 07/03/2026 5:14 pm
Cary
 Cary
(@cary-2)
I tried to update firmware on 3 different USBs before doing a chat with Support. What I posted above is what I went through with Support. If I recall correctly, I don't think you ever see the Prusa logo to push the knob and force a firmware load.
Napsal : 07/03/2026 5:27 pm
Capodelosplasticos
I did it as you described it! And it worked!! Thank you very much!!
Napsal : 08/03/2026 5:11 pm
2 lidem se líbí
