Unloads filament at the start of every print
TurboResearch
(@turboresearch)
After printing for about a week, the Core One now unloads the filament at the start of each print. I think it started after I made a print that used two colors. It is loaded with PLA and the part is PLA. Can't figure out how to just print with the PLA in already loaded.
Postato : 11/04/2025 6:15 pm
darksharpie
(@darksharpie)
RE: Unloads filament at the start of every print
Sounds like you're using the same Prusaslicer file that you were using when you did the 2 color print.  It will maintain the color change command even if you delete the previous objects.
Either create a new Project in Prusaslicer, or when you slice, look at the vertical layer meter to the right and click on any orange horizontal tick marks and hit the X to remove the color change.
Posted by: @turboresearch
Postato : 13/04/2025 12:16 pm
2 persone hanno apprezzato
TurboResearch
(@turboresearch)
Yes, turns out I had a color change on the first layer. It wasn't easy to see, but the clue I missed was the first color in the slicer wasn't orange. Also, if you change legend to color after you slice the part, the time for each color is displayed.
Thanks for Prusa support for helping me figure it out!
Postato : 14/04/2025 4:40 pm
1 persone hanno apprezzato
