Trouble to find the Z axis home position for every print
James He
(@james-he)
It always struggles at beginning of the print.
Try to find the z axis home position and keeps trying.
the bed moves up and down and seems got lost.
I have to try few times before it can continue to finish the real print job.
even I observed that the bed touches nozzle few times and it got lost after and keep moving the bed up and down until fails.
I have firmware version 6.3.2+10364
Thanks,
James
Publié : 24/04/2025 9:24 pm
goldrake
(@goldrake)
RE: Trouble to find the Z axis home position for every print
Hi, I have the same problem as you, did you manage to find a solution?
Publié : 05/05/2025 10:45 pm
Brian
(@brian-12)
Have you tried lubricating the lead screws?
Publié : 05/05/2025 10:50 pm
James He
(@james-he)
Not yet,
My guess now is that I may have a bad loadcell.
Publié : 05/05/2025 10:54 pm
goldrake
(@goldrake)
I'll try right away,
Publié : 05/05/2025 11:00 pm
goldrake
(@goldrake)
nothing to do, I have already replaced the load cell with the one from the mk4, then I replaced the loveboard with the one from the mk4 but the result is always the same.
Publié : 05/05/2025 11:12 pm
James He
(@james-he)
It must be a firmware bug.
I observed few times that the bed is in the middle, and moving up and down try to find the nozzle.
Does Core One has stop switch on z axis to get home position right on first try?
My 10 years old 3D printer can do it on first try. I can't believe this expansive model can not do the simple thing right.
Publié : 05/05/2025 11:47 pm
goldrake
(@goldrake)
It seems that the problem has been solved in my case by replacing this in the G code start.
M109 R{((filament_notes[0]=~/.*HT_MBL10.*/) ? (first_layer_temperature[0] - 10) : (filament_type[0] == "PC" or filament_type[0] == "PA") ? (first_layer_temperature[0] - 25) : (filament_type[0] == "FLEX") ? 210 : 170)} ; wait for temp
With
M104 S100
let me know if it solves for you too
Ce message a été modifié il y a 1 year par goldrake
Publié : 06/05/2025 1:39 pm
James He
(@james-he)
Amazing, you're incredible.
I suffered by this issue for 2+ months, now my core one back to normal.
many thanks, James
Publié : 08/05/2025 5:43 pm
goldrake
(@goldrake)
Great I'm glad. My Core One has other problems as well. I will ask for a replacement
Publié : 08/05/2025 5:57 pm
