TPE-83A Settings
Butters
(@butters)
TPE-83A Settings
I'd like to know what the nozzle settings including the hot bed should be for TPE-83A ?
Opublikowany : 21/12/2025 11:10 pm
OK. Thanks for responding about your Wi-Fi issue. For this filament try a 240° nozzle and 50° bed temperature. Also, what kind of nozzle are you using? Do not use a high flow nozzle with this filament. I also recommend using a 0.6mm nozzle as well. If using a 0.4mm nozzle set the max volumetric flow rate to around 5 mm^3/s
Opublikowany : 21/12/2025 11:16 pm
1 ludzie polubili
Butters
(@butters)
RE: TPE-83A Settings
What is a high flow nozzle you don't suggest ?
Posted by: @hyiger
Opublikowany : 21/12/2025 11:17 pm
Posted by: @butters
Don't use any high flow nozzle. Soft TPU can easily clog the nozzle. Use a standard nozzle and print slow.
Opublikowany : 21/12/2025 11:19 pm
