Steel nozzel
I am currently using the brass nozzle that came with the Core 1. If I change the brass nozzle out for a steel nozzle, will I need to change several temperature settings in Prusa Slicer? Or will changing the settings to the HF0.4 be good enough?
Posted : 19/02/2026 9:42 pm
RE: Steel nozzel
Depends on the nozzle and depends on what you are printing. For the most part you don't need to change anything for now. I'm assuming it's an Obxidian HF nozzle?
Posted : 20/02/2026 12:22 am
