Sharing PrusaSlicer configs between computers running MacOS
Is there a way to easily share configs between two installs (both on MacOS) without resorting to "Export Config Bundle..." and "Import Config Bundle..." across a network share? I'm assuming I should be able to set a startup parameter for PrusaSlicer that points to the config file. What would be easier of course is if Prusa allowed it to be stored in Prusa Connect. But I digress...
I'm assuming it's something like:
open -a "PrusaSlicer.app" --args <something that points to config>
Best Answer by Richard3D:
Yes that is possible
Move the following folder to a network share:
/Users/<username>/Library/Application Support/PrusaSlicer
Delete the original folder from your local machine.
Create an alias (shortcut) to the folder on the network share and place it in the same location as the original folder.
Opublikowany : 14/08/2025 1:02 am
Richard3D
(@richard3d)
RE: Sharing PrusaSlicer configs between computers running MacOS
PrusaCOREOne+
Opublikowany : 14/08/2025 4:01 am
