Seized Nuts foil Core ONE+ upgrade
cyrusjk
(@cyrusjk)
I proudly got into the first round of Core ONE machines released this year, and I have been very happy with it for the most part. I did run into an issue where the nuts used to adjust the belt tension both seized up on me, and I had to replace them (at my small expense), but I figured that it was a one-off issue and everything has worked fine since replacing them up to this point.
I just tried to replace the printhead left cover by removing two simple screws that aren't even under tension, and the lower one seized up on me, causing the nut to tear its hole into a circle. I had to tear it out of the tool head since I also could not screw it back in again. That is three screw/nut combinations that have seized up on me following Prusa instructions. Fixing this would require taking apart the whole toolhead, possibly discovering even more seized nuts.
What is going on here? I've had Prusas since the MK2, and I have never had an issue like this where simply maintaining the machine would cause these failures. What is going on here?
Publié : 24/11/2025 7:07 pm
RE: Seized Nuts foil Core ONE+ upgrade
Steel-on-steel fastener combinations are prone to "galling" -- a very tight connection, like a cold weld, forms between the two parts. Several people have reported that this happened to their belt tensioners.
For the belt tensioners, Prusa now recommends in the kit instructions to lubricate the screws before assembly. There are also community-designed modified tensioner blocks which use a brass insert instead of the square steel nuts.
But this is the first time I read about other screw/nut pairs in the Core One being affected. For that printhead cover, the screw can't have been very tight -- otherwise you would mangle the plastic cover, I'd assume. Maybe the constant vibrations can still cause galling?
Publié : 24/11/2025 7:20 pm
cyrusjk
(@cyrusjk)
It certainly was not a tight nut and was not under tension. It seized only after unscrewing it about 2/3 of the way by hand, so I would assume that the galling was from that action, not the print-head movement. It could just be a bad batch of nuts, but that doesn't make maintaining my printer any easier. I'm at a loss as to the best remedy.
Publié : 24/11/2025 8:36 pm
Fortunately there are not that many of the square nuts -- most screws in the Core One simply use self-tapping threads in plastic, or precut threads in steel sheet material. 🙄
Nevertheless, it is not an attractive proposition to locate all those square nuts to replace the nuts or/and grease the screws. Personally, I would just leave everything as it is, hoping that the nut on the cover was a fluke. The belt tensioner screws are the exception in my opinion, since they have been reported to cause problems quite often. If you have not done so yet when you had to replace them, I would take these out, lubricate and reinstall.
(Then again, maybe the belt tensioner screws have only been found problematic more often because users regularly adjust them, while most other screws are left alone? I dunno...)
Publié : 24/11/2025 8:55 pm
cyrusjk
(@cyrusjk)
I have plans to re-print the tensioners with heat-set threaded inserts to prevent issues with that part of the system, but I shouldn't have to be afraid of upgrading my machine, and I know that is not what Prusa wants, either.
Publié : 24/11/2025 9:43 pm
Conrad
(@conrad-2)
I haven't had my Core One long, but I've had long experience with stainless steel screws. Stainless steel does tend to gall and it's always advisable to lube the threads a bit, especially if it's something that gets adjusted. Because we have so many plastic parts, I'd want a plastic-save lube. I don't know if it exists, but a plastic-safe anti-seize compound would be ideal. Stainless steel screws look good and don't rust, but you'll almost never see a plain black oxide screw gall. They're also stronger.
Publié : 03/12/2025 10:48 pm
cyrusjk
(@cyrusjk)
I'm pretty sure they are chrome or nickel-plated. The issue really isn't "why", it's more "now what?". I have the machine. 3 out of the 4 bolts I tried to unscrew from nuts have seized and destroyed the PC-CF part they were connected to. Knowing this, I want to know if there is anything I can do to prevent this, as injecting a lubricant onto the bolt before turning, or some other trick, like heating it or freezing it.
Technically, this is sould be a warranty fix since it is a defect in materials, but I am loathe to go down that path right now.
Publié : 11/12/2025 3:31 pm
Tim
 Tim
(@tim-21)
Membre
Posted by: @cyrusjk
Hold Prusa responsible so they understand the pain customers feel. Otherwise they have no reason to worry about design decisions that save them money.
Publié : 11/12/2025 5:42 pm
Conrad
(@conrad-2)
Armchair speculation- I haven't tried this so caveat emptor! When I've had stuck filters on cameras, squirting a bit of alcohol in the threads sometimes works. It will wick in quickly where oil has trouble getting. I don't know if it helps with galling. Nice thing is, it then evaporates. Next, I'd try a drip of WD-40, not spray because you don't want it on the belts or anywhere else.
Publié : 11/12/2025 6:45 pm
cyrusjk
(@cyrusjk)
Thanks for the tip, but galling is a hard stop; you need to prevent it because once it happens it's not going to get better. That's why it's so worrysome: now that the C1 is together it's very hard to proactively get in there and lube up the threads.
Publié : 12/12/2025 10:49 am
Conrad
(@conrad-2)
Yes, my suggestions were for the one-off situation where you need to get something apart. I actually contemplated lubing all the screws as I assembled mine, but being an obedient servant, and not seeing anything in the build instructions, I didn't. In hindsight, I would have used a bit of Superlube grease or EM30L on all the screws going into metal, and paraffin wax on the ones self-tapping into plastic. Because the belt tensioners get adjusted periodically, I could make a case for using an actual nickel-based anti-seize lubricant there, but plastic compatibility is bad. It might be better to just replace the screws with regular black oxide steel. What do you suppose the Prusa grease is? I need to look at those square nuts to see what they're made out of. They look like electropolished stainless, not plated, but anything is possible. I work for a place that's terrified of anything showing the slightest trace of rust, so they use stainless hardware for everything. They're also terrified of lubricants contaminating scientific instrumentation, so most everything is assembled dry. I feel your pain!
Publié : 12/12/2025 4:36 pm
Augendoc
(@augendoc)
The square nuts and M3 screws provided by Prusa are stainless steel, which is prone to galling and self-welding much more than regular steel or plated steel. The belt tensioner on my Mk4S galled and welded as I was threading the M3 cap screw through the nylon locknut. Lubing the parts once this happens  will not do anything. Your best bet at this point is to find a way to cut the part out. I used a thin jeweler's saw to cut the screw shaft and remove the fastener without destroying the 3D-printed part. Others have not been so lucky.
The parts most susceptible to this in the Core One are the belt tensioning screws. Your options are to either lube the screws or print new belt tensioners modified to take a brass heat-insert. It's a chicken or the egg thing - you'e got tot get the belt tensioners functioning before you can print new parts.. It's easy to lube the tensioning screws. Open the door, disable the motors, and push the gantry about half way back. Hook your finger over the top of the belt pulley on one side and completely unscrew the cap screw. pull it out and lube the entire length of threads with either superlube grease or anti-seize compound (I used the latter). Slide the screw back in and with your finger supporting the belt tensioner pulley, engage the threads maybe two turns. Repeat on the opposite side. Then adjust both sides exactly the same number of turns, tuning the belt as you go.
Once I got my printer to the point of actually being able to make a print, I downloaded the belt tensioner STL file and used Tinkercad to fill in the space for the square nut and added a 4.7mm diameter cylindrical "hole", essentially enlarging the existing screw hole. I then added a 4.7 x 7mm brass threaded heat insert into each of the newly made holes. Then lubed the screws again and reassembled as above.
Bras is self-lubricating and so will not be susceptible to galling and self-welding with stainless steel. You don't really need to lubricate the threads in this case, but I did anyway.
Publié : 28/12/2025 5:48 am
