Questions about frequent power resets during printing
powerpc750
(@powerpc750)
It really happens a lot that the power resets during printing these days. It can also be reset every few minutes. What is the problem with this? I am in trouble because I can't deal with it because there are no logs left.
Posted : 06/04/2026 1:44 pm
miroslav.h4
(@miroslav-h4)
RE: Questions about frequent power resets during printing
It has been said many times here. Unscrew one of the four screws that hold the X and Y motor from below, remove the powder paint where the screw head was and put the screw back and tighten it well. You can also add a toothed washer under the screw head, and the problem should disappear.
Posted : 06/04/2026 1:57 pm
powerpc750
(@powerpc750)
Thank you, I put a ground wire on the XY motor and it was done.
Posted : 08/04/2026 3:24 am
What is hard for me to understand is why isn't Prusa aware of this issue after 1 year of it being reported? You would think at this point they would at minimum be supplying star washers with their kits.
Posted : 08/04/2026 5:14 am
