Puppy Fehler
Martin
(@martin-43)
Puppy Fehler
Ich hatte heute morgen beim einschalten des Druckers ein Puppy Fehler. #31522 (Core One). QR Code ausgelesen, nach Anweisung Elektronik (Verbindung zwischen xBuddy und xBuddy Extension) geprüft. Optische alles in Ordnung. Drucker wieder neu gestartet. Gleicher Fehler. Dann den Drucker über Reset neu gestartet. Seitdem läuft er. Kennt jemand das Problem ??????
Opublikowany : 08/11/2025 8:45 am
RE: Puppy Fehler
Posted by: @martin-43
This morning, when I turned on the printer, I got a Puppy error: #31522 (Core One). I scanned the QR code and, following the instructions, checked the electronics (connection between xBuddy and xBuddy Extension). Everything looked fine. I restarted the printer. Same error. Then I reset the printer. It's been working since. Does anyone know what the problem might be?
Which firmware version are you using? I've been noticing that more often with 6.4.0-RC. I get it maybe once a week. I've been simply ignoring it.
Opublikowany : 08/11/2025 3:36 pm
1 ludzie polubili
Martin
(@martin-43)
RE: Puppy Fehler
Hallo Hyiger, Firmware-Version 6.3.4+10511. Ich habe Prusa angeschrieben. Solange werde ich es auch ignorieren. Danke für die Antwort.
Opublikowany : 08/11/2025 4:55 pm
RE: Puppy Fehler
Hi Hyiger, firmware version 6.3.4+10511. I've contacted Prusa. I'll ignore it until then. Thanks for the reply.
Yes, I think the consensus is to just ignore it. I raised a similar issue for the 6.4.0-RC firmware so hopefully someone at Prusa is looking into it.
Opublikowany : 08/11/2025 9:23 pm
