Prusaconnect stopped working
Bronk
(@bronk)
I have a 1 month old core 1 and have been using prusaconnect to send and cotrol it. this afternoon, I did a print succesfully and then the next one was ready but showed printer off line.  Nothing has cured this , power cycling and resetting the core 1, my pc. re-registerring with prusaconnect. I get the key code and enter it in but printer still shows off line. Network connectivity is good on ethernet, low on wifi (so I switched to ethernet). Still no luck with re-registering .
Opublikowany : 03/03/2026 12:59 am
Same Old Shane
(@same-old-shane)
Member Admin
RE: Prusaconnect stopped working
Hiya,
Already reported and is being looked into. Checking to see if monkeys got into the wrenches, or if the hamsters need to be fed.
But reports filed, awaiting for resolve.
Shane (AKA FromPrusa)
Opublikowany : 03/03/2026 5:03 am
Bronk
(@bronk)
Thank you. It is working this morning. In the future is there anything I can check other than looking for the "con failed " status in the printer network menu?
Opublikowany : 03/03/2026 2:38 pm
It would be nice if there was a system status page if it is up and running. Or otherwise, maybe prusa3d.com can display a pop-up banner to users if it is not healthy.
Opublikowany : 03/03/2026 4:17 pm
1 ludzie polubili
Same Old Shane
(@same-old-shane)
Member Admin
There is our status page.
https://status.prusa3d.com/
The one main problem with it for the last outage, once the problem was fixed and there was so many reconnect requests, the system took that as  DDOS attack and affected that status page as well.
Opublikowany : 04/03/2026 2:04 pm
1 ludzie polubili
Maybe a pop-up banner or some other style of notification up on the forum pages when there is an outage.
Opublikowany : 04/03/2026 3:16 pm
