Proper scaling for the Prusa Slicer
Robert Hill
(@robert-hill)
When I import a .stl file into the Prusa Slicer, it is typically very good at recognizing that the .stl is in Imperial units and asks me if I want to convert it to Metric.  I agree and off we go.  But, on rare occasion, my .stl could be either Metric or Imperial so Prusa defaults to Metric.  What is the best way to scale that imported part back up in the Prusa Slicer to Imperial size?
Posted : 11/02/2026 9:19 pm
RE: Proper scaling for the Prusa Slicer
I usually only use metric units to design, and "m not sure how Prusaslicer imports metric units, so my advice may be off.
1 inch is 24.5 mm, so if you import say a 1 inch box and it shows up as 1 cm in size, select the part and scale by 245% so the 10 mm box is now 24,5 mm or 1 inch.
If it gets imported as 1 mm, scale by 2450% to get a 1 inch cube.
Posted : 11/02/2026 11:20 pm
One of my peeves is when I see measurement systems being mixed: "I printed a 2" square box with 2mm walls. The room temperature was at 68F but I kept the chamber at 40C"
This post was modified 56 mins ago by hyiger
Posted : 12/02/2026 12:05 am
ssmith
(@ssmith)
One possibility is to right click on the object and look in the dropdown menu for the 'Convert from...' options.
Posted : 12/02/2026 12:21 am
