Printing direct from USS Drybox on Core One+
nurdok
(@nurdok)
Mitglied
Running the Prusa USS Drybox on my Core One+ and wanted to share early experience plus two open questions.
The box has an opening that fits either the bare filament or a PTFE tube. I tried printing with the filament sticking out directly (no tube) on a 5h print — worked perfectly, and the internal humidity sensor read 10% both before and after. I'm wondering if I actually need to use a PTFE tube for this connection or can I just use it as it is. The filament touches the drybox and bends a bit in its route to the printer. I thought it would be a problem but it seems to work fine (with PLA):
My big problem is unloading. The Core One has a long filament buffer from the filament entrance to the extruder, so there's a lot of buffer to pull out when unloading filament. Since the spool sits inside the sealed box, I can't rewind the slack back onto the roll, so I'm left with a long length of filament hanging out with nowhere to go (photo below). What's the best way to deal with this?
I haven't printed the official PTFE tube solution yet — but as far as I can tell it only protects the filament from being exposed to humidity during feeding and doesn't help the unloading problem. Am I missing something, or is there a trick to this?
Veröffentlicht : 22/05/2026 12:54 pm
RE: Printing direct from USS Drybox on Core One+
I think the "official solution" is to open one of the side flaps, put your finger in there, and wind the filament back onto the spool.
Veröffentlicht : 22/05/2026 5:14 pm
nurdok
(@nurdok)
Mitglied
Posted by: @foxrun3d
You mean through the desiccant openings? Seems very awkward and quite a hassle.
Veröffentlicht : 22/05/2026 5:32 pm
Having to open the sealed, dry-air environment is a bit disappointing. Maybe glue a large iron washer to the side of each spool and rewind it from the outside with a magnet? (One can make it slightly fancier and stick thin felt pads or such the washer and the magnet, to avoid scratching the USS box.)
Veröffentlicht : 22/05/2026 6:06 pm
Or perhaps Prusa could come up with an AMS2 Pro style alternative with active rewind and a built in filament dryer. But then Prusa seems to have an aversion to copying innovators.
Veröffentlicht : 22/05/2026 6:23 pm
Adding all those active components is not so easy if you can't throw cheap injection-molded parts and PCBs at everything. (Since you don't have the scale and the cheap-stuff ecosystem around you.) So I understand and kind of like Prusa's "let's keep it simple" approach.
I suspect I might understand and like it even more once the first components in my Bambu H2D start to fail...
Veröffentlicht : 22/05/2026 6:31 pm
nurdok
(@nurdok)
Mitglied
Very disappointing. I bought 10 of these, thinking I'll put all my open spools in these dryboxes. I guess I'll just use them for non-PLA spools.
Veröffentlicht : 22/05/2026 7:34 pm
I bought two and I'm not excited. The fact that you have to use an adapter to avoid non-Prusament filament from dragging just WTF. The whole thing feels like a Kickstarter, not a product tested in a real life environment.
Veröffentlicht : 22/05/2026 11:20 pm
Posted by: @jurgen-7
AMS blows up after warranty and I can't repair it? Cheap enough to just buy another.  But agree that the H2D will be in a landfill well before the Core One is.
Still even a spring loaded spool reel would be better.
Veröffentlicht : 22/05/2026 11:27 pm
