Precision Homing Failed
Bob Keeney
(@bob-keeney)
Miembro
Just finished the build from kit and doing the calibrations.  Y failed at first (had to loosen) and then X and Y passed but Precise Homing Failed.  At this point I'm kind of stuck.  Any suggestions on how to proceed?
Best Answer by hyiger:
Since it's a kit, I'm assuming this is the Core One and not the Core One L.
Loosening or tightening the belts unevenly to square the gantry is what is causing this issue. Homing failed because the gantry is now skewed. To correct, try the following:
  1. Loosen both tension screws until the pulley detaches from the screw, then reattach both tightening just until the screw is threaded
  2. Move the gantry to the front of the print and check that it is hitting the stops on both sides at the same time. If one side is skewed (there is play) then wedge something on the opposite side like the flat side of the universal wrench, then slightly bend the side with play by hand. Then recheck.
  3. Once square then tighten the tension screws. They must be tightened by the same amount alternating between them. So left 2 turns, right 2 turns. Do this until the belts start to tighten. Then left 1 turn, right 1 turn. Next left 1/2 turn, right 1/2 turn.
  4. Move the gantry and printhead to the center then move the gantry forward by hand checking that both sides still hit the stops at the same time.
  5. Next run the Manual Belt Calibration wizard.
  6. Once the belts are in the correct range with the upper belt 3-6 hz greater than the lower belt, homing should now pass
  7. If the lower belt has a higher frequency than the upper belt, then go back to step one and redo the tension again.
The key point is your gantry has to be square (parallel to the front of the printer) and both left and right tension screws must always be tightened or loosened by the same amount. Never turn them independently of each other.
Respondido : 22/12/2025 7:09 pm
Respondido : 23/12/2025 1:57 am
Bob Keeney
(@bob-keeney)
Miembro
RE: Precision Homing Failed
Thanks.  I actually figured it out a few hours after I posted this.  I need to reread that section of the installation manual to see if needs a tweak.
Respondido : 23/12/2025 1:46 pm
1 les gusta
Augendoc
(@augendoc)
After you have aligned the gantry and gotten the belts tuned, you should notice reduced head banging. Even so, Prusa says something like eight head bangs is normal. Anything more than that means your belts are not tuned or the gantry is misaligned. Also, if you are just first using your machine, don't hesitate to go back every few days and recheck the tuning on your belts. I think they loosen up a bit at first when new.
Respondido : 28/12/2025 4:57 am
