Powersave mode
TeMpL
(@templ)
Powersave mode
Why is no powersave mode implemented?
To turn of lighting an tur of display (burnin)!
After printer is not in use or printing for 30 min?
It could resume on opening a door or sending a file, or touching a display or rotating a dial..
This topic was modified před 2 weeks by TeMpL
Napsal : 12/04/2026 9:20 am
miroslav.h4
(@miroslav-h4)
RE: Powersave mode
Unfortunately, turning off the display is not implemented, but if you want to turn off the chamber lighting when not printing, you will probably be surprised, but this is implemented in the C1! Feel free to set it to your liking! I won't tell you where it is located in the menu, please get to know the printer properly!
Napsal : 12/04/2026 2:52 pm
TeMpL
(@templ)
RE: Powersave mode
Hmm.. you can se to dim lighting after print thats ok..  as you stil need a light after print.. to wait fo coool dow an takin parts out..
but nothing aboutinactivity..  as only sope preheating is implemented after 30 minutes..
maybe with some gcode in print job/slicer whit thease am not familiar yet.. as an have a printer only fo a month..
Napsal : 12/04/2026 3:05 pm
mnentwig
(@mnentwig)
RE: Powersave mode
If energy consumption matters, you might want to power down Z steppers (at the risk of losing bed leveling stored in "mechanical memory"). I suspect they'll contribute significantly to standby power consumption.
Napsal : 12/04/2026 3:10 pm
TeMpL
(@templ)
RE: Powersave mode
my main concern is light pollution and display burin ..
and most of devices are in year 2026 able to go to sleep...
Napsal : 12/04/2026 11:27 pm
