PEI sheet business model? 😉 Or just a faulty sheet?
Do you have dents in you Core One pei-sheet Poll is created on Oct 29, 2025
Mafke
(@mafke)
Hi all,
I assembled my own prusa over last summer, it gives me great prints even without any VFA, which is great. It is my third Prusa printer after owning a MK3 and a MK4.
Today, after printing around 35 prints in 2 months I can see my pei-sheet that was delivered with my Core One has a lot of small dents.
The are most probably from the nozzle pushing agains the sheet when auto-leveling.
Do you also have this? Or do I have a bad pei-sheet? Will Prusa replace mine under guarantee?  I put some photo's to show, but the dents are tiny so they are hard to find...
Este debate ha sido modificado el hace 6 months 2 veces por Mafke
Respondido : 29/10/2025 4:09 pm
Mafke
(@mafke)
RE: PEI sheet business model? 😉 Or just a faulty sheet?
I am adding the photo's here
Respondido : 29/10/2025 4:34 pm
Prusa won't replace something due to user error. They consider the build plates to be a consumable item. If you received it from Prusa this way, then they would be under obligation to replace it.
I suspect that your nozzle and heat block assembly are incorrectly inserted into the heatsink. The load cell is sensitive enough that the nozzle shouldn't be plowing into the sheet like this.
Respondido : 29/10/2025 6:22 pm
chmax
(@chmax)
I had one or two of those dents in the very few weeks of my MK4 where the firmware was still not soooo stable and some bad poking happened. If I look at photo n3, those are not dents, they are holes, something really poked badly... as @hyiger said, check your assembly, go through setup again, especially the load cell test, just to be on the safe side.
You may be able to correct some of these by turning the sheet over and letting the heat of a few prints work on the plastic...
Respondido : 30/10/2025 4:33 pm
1 les gusta
Edwin
(@edwin-5)
Miembro
TS is definitely not the only one. I've got the same issue. I've run about 3o-ish prints and have the same issue.
It's a pre-assembled Core One, So no user error, and I didn't change any hardware settings....
I know that the sheets are regarded as consumables, but my 2 Mini's still use the same PEI sheet and have been working for years and have easily 200+ prints on them. As I use them to teach 3D printing for about 30 weeks a year at schools.
Respondido : 23/12/2025 3:01 pm
