Overhangs towards the back print better?
While trying to tweak printing parameters for a critical overhang (which I would much prefer to print without supports), I found that my Core One prints overhangs much better when they are oriented towards the back of the printer. Is this a known phenomenon, or is something wrong with my print head?
Most likely this is due to uneven airflow from the fan shroud -- it might not be quite as "360 degree" as Prusa advertises? If that is the root cause and a design issue on all Core Ones (rather than a flaw on my unit), I would expect the MK4S to show a similar asymmetry, but with better cooling and hence overhangs towards the front. Is that the case?
Veröffentlicht : 06/10/2025 8:17 am
