Noise while printing
NicholasNDB
(@nicholasndb)
I've printed probably 100-120 hours so far with the core one. The print I started up today has this weird squeaking noise. It does slow down and speed up as printer slows and speeds up. I was thinking it may be belt tension based on some similar posts, but I'm not sure. I'm also not sure if this is related, but I did update firmware from 6.2.3 to 6.3.3
Does anyone have any ideas on what this is or what to check?
Postato : 06/07/2025 3:49 pm
NicholasNDB
(@nicholasndb)
RE: Noise while printing
Postato : 06/07/2025 3:51 pm
NicholasNDB
(@nicholasndb)
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/07/7b332671-pxl_20250706_153432363.mp4
Postato : 07/07/2025 12:55 am
SgtCaffran
(@sgtcaffran)
This simply appears to be the nozzle scraping the top surface of the print. In this case the infill causes this noise. Use a different infill to reduce the noise.
Postato : 07/07/2025 12:05 pm
