No chamber temperature control when using orcaslicer?
Snacksiddent
(@snacksiddent)
Hey,
I noticed that my C1 doesn't control the chamber temperature at all, even though I've set the chamber temperature in the filament profile settings in orcaslicer (alpha version 2.3.1 - maybe that's the cause?). For example while printing with ASA yesterday (chamber temp in slicer set to 45 degrees) the chamber got as hot as 61 degrees. When I checked the tuning menu the max chamber temp setting was off - I had to manually set the max temp and it wasn't the first time.
Also did anyone else run into issue where during a longer print with 50 degree chamber the double sided tape holding the handle would let go?
Napsal : 15/07/2025 6:44 am
Raaz
 Raaz
(@raaz-2)
RE: No chamber temperature control when using orcaslicer?
Mine is getting loose from only printing PLA/PETG with a maximum of 35°C in the chamber, most of the time more like sub 30°C.
Seems like that tape is falling off after some anyway. I'm going to screw the handle on.
Napsal : 18/07/2025 7:43 am
