New C1+Kit - Strange clicking/rattle noise from Y-axis stepper area
Page 1 / 2
Steve
(@steve-27)
I recently finished assembling a new Core One plus kit I received before Christmas. Assembly went smooth, and I've been happily printing with it for the last few weeks. In the last week or so, it has developed a clicking/rattle noise coming from the Y-Axis stepper motor area. The clicking noise is in time with movement of the lower belt only. I've confirmed the noise is not coming from the linear bearing.
I have tried loosening and re-tensioning the belts, but it made no difference. Print quality doesn't appear to be affected, but the noise is a little annoying, seems to be getting louder and I'm concerned it might cause premature wear.
Video of clicking/rattle noise:
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/01/7f96b6a3-pxl_20260122_0819381542.mp4
Any suggestions on how to fix this? I feel like it's either coming from the stepper or a bearing.
Posted : 22/01/2026 8:59 am
Steve
(@steve-27)
Video didn't appear to attach to above post:
See here https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/01/7f96b6a3-pxl_20260122_0819381542.mp4
Posted : 22/01/2026 9:09 am
RE: New C1+Kit - Strange clicking/rattle noise from Y-axis stepper area
Hi Steve, the video link in the first post, had some formatting data in front and behind the URL, which stopped the forum from displaying the information.
I edited out the formatting data and the link now works.
Joan
Posted : 22/01/2026 9:15 am
Conrad
(@conrad-2)
A guess. Somebody had a similar noise where the belt teeth were hitting the head of a zip tie. Follow the belt path and see if there's anything like that going on. The noise sounds like about the right frequency.
Posted : 22/01/2026 3:25 pm
Yep. This sounds like the belt rubbing against the zip tie that holds the chamber thermistor against the chamber fan grill in the back of the printer.
Posted : 22/01/2026 4:52 pm
Steve
(@steve-27)
@Conrad, @hyiger I was so sure you guys were on to it, but alas, I just checked and the rattle is not from the belt rubbing on a zip tie. The lower belt actually clears it by some margin (the top belt is closer, but also not rubbing).
Another video: https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/01/29b03d11-pxl_20260123_1031364483.mp4
I'm going to try swapping out the idler pulley this weekend and see if that makes any difference.
Posted : 23/01/2026 11:10 am
abmantis
(@abmantis)
You can try to isolate the noise by moving the motor diagonally. On diagonal will only move the upper belt (and motor) while the other moves the other belt.
If it happens on both diagonals, then it not related to motors or the pulleys (except the 4 that move back/forward with the X axis mount).
You can use some gcode to do that (or a print with a rotated cube), or disable the motors and move it by hand (it moves more "freely" with the diagonals so it is not hard to hit the perfect movement).
Posted : 24/01/2026 1:35 am
Steve
(@steve-27)
Yeah, the rattle definitely only occurs when the bottom belt moves (either by stepper or when I manually move the belt). The best I can tell, it's coming from back right corner, possibly the Y-Axis stepper or pulley).
Posted : 24/01/2026 1:57 am
Conrad
(@conrad-2)
You might find it by listening through a piece of 1/4" or 3/8" flexible tubing. One end to the ear and move the other around so see if it's louder at some location.
Posted : 24/01/2026 1:59 am
Steve
(@steve-27)
Good news! The rattle is gone.
The bad news... I don't really know why. 🤔 I spent the last hour disassembling the Y-Axis assembly. I loosened/removed the stepper, idler and toothed pulleys, reassembled everything, re-tensioned the belts and the rattle is gone. 🤷‍♂️
Posted : 24/01/2026 10:07 am
abmantis
(@abmantis)
I just noticed that mine also does it when moving the upper belt, but it is very subtle and doesn't always happen. It is most noticeable if I move the left belt manually with the steppers disabled. My bet would be one of the pulleys in the motor mount, but haven't been able to confirm it.
Hopefully it does not start to get louder, so I'll try to ignore it 😀
Posted : 24/01/2026 10:19 pm
Steve
(@steve-27)
I spoke too soon. The rattle has come back 😕
@abmantis, it's interesting you're hearing it also, but on the top belt. And I think you might be on to something re: it being a pulley. I wonder if it's a pulley "clicking" over a thread on the M3 bolt that's used the pin.
I was thinking of swapping out the M3 bolts for M3 dowels/pins with threaded ends. Would need M3x30 and M3x18 I believe.
Something like:
https://www.amazon.com.au/Stainless-Slotted-Cylindrical-External-M3/dp/B0B7S4R2B7?th=1
Posted : 26/01/2026 2:54 am
Most of the noise (in my case) was resonance with the metal frame.  I loosened and lightly retightened most the screws connecting motors and pulley to the frame and it substantially cut the noise. I also ran phase stepping calibration which further reduced the noise.
Posted : 26/01/2026 2:36 pm
abmantis
(@abmantis)
Could be. Skates use that type of screws to hold the bearings too. It can also be some bad bearing (or just dirt in it).
I hope I don't have to, but if the noise gets worse over time I will probably disassemble the motor part to take out the bearings and check them individually.
Posted by: @steve-43
Something like:
Posted : 26/01/2026 2:53 pm
abmantis
(@abmantis)
Mine started making more noise. It is coming from the front left pulley (where the tensioner screw is). Putting a finger on it I could feel it "click" while rotating.
I've removed it and moving it with a string while holding the pulley mount I can feel the "click" too. I assume one of the bearings is defective.
Posted : 07/02/2026 1:49 pm
abmantis
(@abmantis)
And here is a video. The best way I've found to be able to amplify the noise is running it on a table. You can clearly hear something like "train tracks" at around 5s.
You can also feel it very well on your fingers if you rotate it with a string for example and even when it was mounted and printing.
Posted : 07/02/2026 3:50 pm
abmantis
(@abmantis)
Comparing the two bearings in the pulley, one is really bad.
Bad bearing side: https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/02/f898cf01-bad_bearing_side.mp4
Good bearing side: https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/02/afe27224-good_bearing_side.mp4
Posted : 07/02/2026 4:21 pm
Steve
(@steve-27)
Nice find @abmantis! I'm betting I've got the same issue. I'm going to check my belt tensioner idler bearings this evening.
Posted : 09/02/2026 3:54 am
Steve
(@steve-27)
@abmantis I can confirm I too have a bad idler pulley/bearing. In fact, I have two! One in the X-axis stepper assembly, and another in the Y-axis stepper assembly.
Like you, if I run the idler across a desk, I can feel and hear the roughness/rattle.
I'm going to reach out to support and see if they will send me a set (with that sort of failure rate, I'm not confident I would receive two good pulleys...)
Posted : 14/02/2026 12:59 am
Steve
(@steve-27)
Update:
TLDR; Rattle noise is completely gone after replacing idler pulley bearings and using proper 3mm threaded dowel pins.
So I reached out to Prusa support and they very promptly sent me two replacement pulleys. However, both of them also had bad/notchy bearings!? Interestingly, they both also looked used (witness marks on the pulley surface). I didn't bother contacting support again, and decided to source my own bearings.
I completely replaced all pulley bearings and pins with these APE ABEC-9 693ZZ bearings, and 3mm slotted/threaded dowel pins (4x30mm and 8x18mm). Pressing out/in the bearings from the pulleys was very easy.
The difference was huge. Print head motion is much smoother and quieter now. I'd be very curious what others find from the inexpensive mod.
This post was modified 2 months ago 2 times by Steve
Posted : 21/03/2026 11:07 pm
4 people liked
Page 1 / 2
