New C1+Kit - Strange clicking/rattle noise from Y-axis stepper area
Steve
(@steve-43)
I recently finished assembling a new Core One plus kit I received before Christmas. Assembly went smooth, and I've been happily printing with it for the last few weeks. In the last week or so, it has developed a clicking/rattle noise coming from the Y-Axis stepper motor area. The clicking noise is in time with movement of the lower belt only. I've confirmed the noise is not coming from the linear bearing.
I have tried loosening and re-tensioning the belts, but it made no difference. Print quality doesn't appear to be affected, but the noise is a little annoying, seems to be getting louder and I'm concerned it might cause premature wear.
Video of clicking/rattle noise:
https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/01/7f96b6a3-pxl_20260122_0819381542.mp4
Any suggestions on how to fix this? I feel like it's either coming from the stepper or a bearing.
This topic was modified 5 days ago by JoanTabb
Posted : 22/01/2026 8:59 am
Steve
(@steve-43)
Video didn't appear to attach to above post:
See here https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/01/7f96b6a3-pxl_20260122_0819381542.mp4
Posted : 22/01/2026 9:09 am
RE: New C1+Kit - Strange clicking/rattle noise from Y-axis stepper area
Hi Steve, the video link in the first post, had some formatting data in front and behind the URL, which stopped the forum from displaying the information.
I edited out the formatting data and the link now works.
Joan
Posted : 22/01/2026 9:15 am
Conrad
(@conrad-2)
A guess. Somebody had a similar noise where the belt teeth were hitting the head of a zip tie. Follow the belt path and see if there's anything like that going on. The noise sounds like about the right frequency.
Posted : 22/01/2026 3:25 pm
Yep. This sounds like the belt rubbing against the zip tie that holds the chamber thermistor against the chamber fan grill in the back of the printer.
Posted : 22/01/2026 4:52 pm
Steve
(@steve-43)
@Conrad, @hyiger I was so sure you guys were on to it, but alas, I just checked and the rattle is not from the belt rubbing on a zip tie. The lower belt actually clears it by some margin (the top belt is closer, but also not rubbing).
Another video: https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2026/01/29b03d11-pxl_20260123_1031364483.mp4
I'm going to try swapping out the idler pulley this weekend and see if that makes any difference.
Posted : 23/01/2026 11:10 am
abmantis
(@abmantis)
You can try to isolate the noise by moving the motor diagonally. On diagonal will only move the upper belt (and motor) while the other moves the other belt.
If it happens on both diagonals, then it not related to motors or the pulleys (except the 4 that move back/forward with the X axis mount).
You can use some gcode to do that (or a print with a rotated cube), or disable the motors and move it by hand (it moves more "freely" with the diagonals so it is not hard to hit the perfect movement).
Posted : 24/01/2026 1:35 am
Steve
(@steve-43)
Yeah, the rattle definitely only occurs when the bottom belt moves (either by stepper or when I manually move the belt). The best I can tell, it's coming from back right corner, possibly the Y-Axis stepper or pulley).
Posted : 24/01/2026 1:57 am
Conrad
(@conrad-2)
You might find it by listening through a piece of 1/4" or 3/8" flexible tubing. One end to the ear and move the other around so see if it's louder at some location.
Posted : 24/01/2026 1:59 am
Steve
(@steve-43)
Good news! The rattle is gone.
The bad news... I don't really know why. 🤔 I spent the last hour disassembling the Y-Axis assembly. I loosened/removed the stepper, idler and toothed pulleys, reassembled everything, re-tensioned the belts and the rattle is gone. 🤷‍♂️
Posted : 24/01/2026 10:07 am
abmantis
(@abmantis)
I just noticed that mine also does it when moving the upper belt, but it is very subtle and doesn't always happen. It is most noticeable if I move the left belt manually with the steppers disabled. My bet would be one of the pulleys in the motor mount, but haven't been able to confirm it.
Hopefully it does not start to get louder, so I'll try to ignore it 😀
Posted : 24/01/2026 10:19 pm
Steve
(@steve-43)
I spoke too soon. The rattle has come back 😕
@abmantis, it's interesting you're hearing it also, but on the top belt. And I think you might be on to something re: it being a pulley. I wonder if it's a pulley "clicking" over a thread on the M3 bolt that's used the pin.
I was thinking of swapping out the M3 bolts for M3 dowels/pins with threaded ends. Would need M3x30 and M3x18 I believe.
Something like:
https://www.amazon.com.au/Stainless-Slotted-Cylindrical-External-M3/dp/B0B7S4R2B7?th=1
Posted : 26/01/2026 2:54 am
Most of the noise (in my case) was resonance with the metal frame.  I loosened and lightly retightened most the screws connecting motors and pulley to the frame and it substantially cut the noise. I also ran phase stepping calibration which further reduced the noise.
Posted : 26/01/2026 2:36 pm
abmantis
(@abmantis)
Could be. Skates use that type of screws to hold the bearings too. It can also be some bad bearing (or just dirt in it).
I hope I don't have to, but if the noise gets worse over time I will probably disassemble the motor part to take out the bearings and check them individually.
Posted by: @steve-43
Something like:
Posted : 26/01/2026 2:53 pm
