My new core one is having WiFi issues
Pagina 1 / 2
MEETHREEDEE
(@meethreedee)
I have tried the WiFi wizard and manually entering my WiFi info and the nfc won’t work either I’ve tried it on 2 different phones too. I’m hoping Prusa will send me another WiFi deal. I have tried to enter my wifi info manually. i have done the wifi wizard and the nfc is also not working im hoping mabe if i connect with ethernet i can do an update and possibly fix it.
Questa discussione è stata modificata 1 year fa da MEETHREEDEE
Postato : 28/04/2025 3:48 pm
RE: My new core one is having WiFi issues
The error message suggests a hardware problem, and I have not read about any firmware issues which would cause this (and could be remedied by an update). You can check that the Wifi module is properly installed; see the kit assembly instructions for guidance. But you will probably need to contact customer support for further troubleshooting help and possibly a spare part.
You mention that NFC is also not working -- how do you know that? If NFC is indeed not functional, I believe that would point towards a problem on the xBuddy board, because WiFi and NFC share the same chip but use separate antennas and connections. But NFC is temperamental (and of limited use) in the Core One, so the lack of NFC functionality might just be a compatibility or handling problem. You need to know where exactly your phone's NFC antenna is and place that right over the Core One's antenna.
Postato : 29/04/2025 5:07 am
Oh, one other (and much simpler) option: Several users have reported that they could not connect to WiFi if the SSID or the password contained special characters, including '$ ' or spaces. Not sure what the error messages says in that case, but if your network login info has such special characters, try setting up a network with plain alphanumeric credentials.
Postato : 29/04/2025 5:53 am
Chris Hill
(@chris-hill)
I had the same issue the first time I powered up my kit-built CORE One.  I'm not certain of the sequence now, but I think I loaded the latest firmware (COREONE_firmware_6.3.2.bbf) onto the USB before the first power up, and after it flashed the firmware it began the self-tests.  It failed at the first step, which is to set up the networking, so I cancelled that and ran through the remainder of the self-tests.  At the next power up it then flashed the necessary files onto the wifi module and I was able to get the networking set up properly.
I don't know why it didn't flash the wifi module when I first loaded the firmware - maybe it's an odd combination of updating the firmware while still needing to do the self tests.
Postato : 29/04/2025 7:27 am
Kachidoki
(@kachidoki)
Hi, about the special characters, it is a different issue. The NFC cannot transmit accented characters, it replaces them by '?' and the local keyboard on the printer screen does not provide it neither. The only way I could connect to this WiFi was by scanning networks on which the specials characters are displayed (at least this one), and type the password manually. Hopefully I found each character from the password on the local keyboard.
I don't know if it works from the old config file technique.
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4629
Below the example with "WiFi lé la"
So it is a totally different issue here as the printer reports a problem with the wifi module. I would suggest the reseat the module first, maybe reflash the printer firmware then, I am not sure when the printer performs a flash of the wifi module.
Postato : 29/04/2025 7:37 am
Kyosuke_14
(@kyosuke_14)
Same message for me at the first start. I pass, make all calibrations, restart the printer and go to the wifi section and it work.
Postato : 29/04/2025 11:11 am
Chris Hill
(@chris-hill)
Posted by: @kyosuke_14
So it seems possible that the wifi module doesn't get it's firmware flashed until the first run through the self tests.  Was yours with the default firmware file on the USB (6.3.1 in my case), or did you also fetch 6.3.2 before first power up?
If indeed it waits for the first self-test before flashing the wifi module, it's odd that it should make connecting to wifi the first thing it attempts.
And I wonder if it needs a successful pass through the self-tests before it allows the wifi module to be flashed.
Or maybe the self-tests have nothing to do with it, and it just needs a reboot after the first firmware flash (which seems more likely).
Postato : 29/04/2025 12:41 pm
Kyosuke_14
(@kyosuke_14)
Default firmware file on the USB, but mine was 6.3.2
I think that after the firmware was installed, the printer need to be reboot to load the wifi module, but instead of that, the self test start.
Postato : 29/04/2025 1:00 pm
Cédric
(@cedric)
Same for me, i thought it was first worth a try restarting before opening up the back of the printer, thankfully it worked.
Postato : 29/04/2025 1:18 pm
Chris Hill
(@chris-hill)
Perhaps just an incorrect order of precedence for what needs to be done first when there is more than one outstanding necessary step in the queue - perhaps the need for a self-test overrides the need to reboot.  But if this is the case, wouldn't everyone experience the same situation?  Or perhaps this new sequence was introduced with 6.3.2?
Postato : 29/04/2025 2:13 pm
Chris Hill
(@chris-hill)
Posted by: @cedric
Ah, 'tech support 101' 🙂
"Have you tried turning it off and on again?"
Postato : 29/04/2025 2:17 pm
1 persone hanno apprezzato
Chris Hill
(@chris-hill)
Ifti has provided another data point that fits the pattern, i.e. that with 6.3.2 a reboot after completing the self-tests will get the firmware to flash the wifi module.  I wonder if it's sufficient to just do a complete run through the self-tests, or whether it actually needs to pass them all.
Postato : 01/05/2025 1:18 pm
MEETHREEDEE
(@meethreedee)
So I think I got it to connect to the network because It took my password and now I see the little WiFi symbol in the top corner. But I still can’t connect to PrusaLink or PRUSA app. Support told me my WiFi needs to be a certain frequency or something. Does anyone know how to find out what my WiFi frequency is ?
Postato : 01/05/2025 5:07 pm
Butters
(@butters)
Did the WiFi Wizard work for you or everything failed ?
Posted by: @meethreedee
Postato : 05/12/2025 3:53 pm
Posted by: @butters
Please be more specific. What did you try to make it work? What failed? Does your phone have an NFC/RFID transmitter? If so then it's easier to use the app on your phone to set it. Otherwise, in the UI WiFi Wizard just enter the credentials manually.
Postato : 05/12/2025 4:08 pm
Butters
(@butters)
The OP did mention his Wizard is not working as well.
Why isn't the Wizard working and do you have a link to enter the credential manually ?
Posted by: @hyiger
Posted by: @butters
Postato : 05/12/2025 4:18 pm
Posted by: @butters
Posted by: @hyiger
Posted by: @butters
Settings -> Network -> WiFi -> WiFi Wizard -> Enter Credentials Manually
Postato : 05/12/2025 6:06 pm
Posted by: @butters
@butters imagine that you are talking to your doctor and say the following:
Butters: Hello doctor, I have a pain
Doctor: Where is this pain?
Butters: In my arm
Doctor: Where in your arm
Butters: It's in my elbow
Doctor: OK, when did you get this pain?
Butters: I got it yesterday
Doctor: OK, what were you doing yesterday that caused this pain
Butters: I was playing a sport
Doctor: (by now irritated) WHICH SPORT?
Butters: I was playing volleyball
Doctor: (hangs up the phone)
Instead of:
Butters: Hello doctor, yesterday I was playing volleyball and when I jumped to spike the ball my elbow over extended and now it hurts
Doctor: OK, it's probably a sprain but lets get it x-rayed just in case.
In the first example, this is how you have been interacting with the forum. So if you have a problem you need to describe in detail what the problem is, what steps you took to get there and what the expected outcome should be. Then it will make it easier for us to give advice.
Postato : 05/12/2025 6:16 pm
Butters
(@butters)
You're first example; I've had a doctor ask me in this way. I understand your point but I still don't know why off hand the Wizard won't work.
Posted by: @hyiger
Posted by: @butters
Butters: In my arm
Instead of:
Postato : 06/12/2025 12:03 am
Posted by: @butters
I'll help you but you need to do the following:
  1. Explain which wizard function did you run?
  2. Did you run it on the firmware UI or with the Prusa App?
  3. What was the error that you see?
  4. Please take a photo of the error
  5. Did you try to manually setup the wifi?
Postato : 06/12/2025 12:20 am
Pagina 1 / 2
