MMU3 Layer shift On core one 6.4.0-alpha
Alienbliep
(@alienbliep)
Goodday,
Today i had an massive layer shift while printing with the core one mmu. Only optioun i always use is the sparse layer on the wipe tower.
Is this a one time occasion? I have been printing daily for to months and this never happened before.
I upgraded to new 6.4.0-alpha yesterday could that be the issue.
I already printing these minions once succesfully, but that was an other gcode.
Thanks in advance,
Stefan
Publié : 12/09/2025 5:36 pm
Alienbliep
(@alienbliep)
RE: MMU3 Layer shift On core one 6.4.0-alpha
Hmm it is happening again.
I think it is this blob on the wipe tower that causes it. I can hear the head crashing into it.
The only thing i changed after the correct 3x minion print was up the purge voumes from 100mm3 to 140-180mm3 because color was not ok.
It seems to happen on after the fast unload wipe before it starts ramming. there is an slow movement in between and there it happens.
Publié : 13/09/2025 8:33 am
Das-Werkshopz
(@das-werkshopz)
Have you found an answer to this yet? I have also experienced the same layer shifts from hitting the blob created in the wipe tower.
Publié : 26/09/2025 5:10 pm
Alienbliep
(@alienbliep)
No i did not find an answer. Haven't printed with the mmu alot since. It happens every time though.
I do not do a lot of mmu prints.
Mainly use the mmu the load al spools from different buildplate and then assembly the print. I like to assemble things. 😁
Publié : 04/10/2025 4:41 pm
SirMakesALot
(@sirmakesalot)
Membre
Layer shiftI too am having layer shift. It is happening over and over again. I have had the printer running just fine for the past few weeks and all of a sudden im getting layer shift. Not at the same layer either. I have tightened the belts and ran a test print and that came out just fine. Then I change the filament to my specialty filament and run and sure enough i get a layer shift.
Is there any way for me to find out which was the last layer printed and start remove the shift and restart from a specific layer ?
How do you turn on crash detection? It doesnt seem to be showing or i cant find it.
Single material, .4 nozzle .25 layer height. PLA Silk and dont see any warping. NEED HELP fixing please
Ce message a été modifié il y a 9 months par SirMakesALot
Publié : 04/10/2025 6:38 pm
James Kirk
(@james-kirk)
I have had the same problem several times on the core one.
I don’t know why the blob occurs in the wipe tower, but I could see the layer shift happened there
It never happened on my mk4s.
So now I do most of my multicolor prints on the mk4s and only single Color on the core one.
Publié : 04/10/2025 7:30 pm
Alienbliep
(@alienbliep)
Ok. Hmm
Do we need to sent this to support?
I dont know how.
Publié : 04/10/2025 7:34 pm
Posted by: @alienbliep
Ok. Hmm
I dont know how.
Please try the 6.4.0-RC firmware first. If still an issue, you can submit a bug report here: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues Click on the green "New Issue" button at the right of the screen.
Publié : 04/10/2025 9:57 pm
Alienbliep
(@alienbliep)
I tried 6.4.0. the day it released and haven't encountered the layer shift anymore.
I have not just the mmu much since either. Just for 3 or 4 models.
I think it helped.
Publié : 19/10/2025 9:22 pm
red_clay
(@red_clay)
Membre
I've been suffering with this for months, and either got lucky today or found a fix (in some sense).
Print failed with multiple attempts
50% speed - failed
Disabled Arc Fitting - failed
Bypassed MMU - failed
Downgraded firmware - failed
Downgraded slicer - failed
Upgraded firmware - failed
Said "ok, time to see what I can recalibrate". First place I went was the Input Shaper screen. X and Y-axis Filters were set to "Null". Hit "Restore Defaults" and it worked twice in a row.
Tried an iteration that had failed earlier - success!
Now, I don't remember if I had set those to Null in previous troubleshooting attempts. I *know* I had seen these setting at "EI" as they defaulted to. I had loaded up the alpha and then the RC versions of the current firmware as they came available. Is it possible that the Input Shaping settings were set one way and showing another, and downgrading then upgrading reset that to properly show "Null"?
Does anyone who's been having this trouble want to try messing with and resetting their Input Shaping settings?
Publié : 30/10/2025 1:10 am
