Mesh bed leveling. Multiple probes at one point ?.
Hi, I noticed when mbl is running. It usually probes one point than moves to the next one. But often it only moves a tiny bit and tankes another probe and moves a bit and probes a third time. Than moving on to the next probe point. (One probe or 3 again)
the nozzle is clean and tight. Bed is clean.
do you notice that too ?
Publié : 07/08/2025 8:24 pm
RE: Mesh bed leveling. Multiple probes at one point ?.
Hi, it is normal, it probably detects plastic within nozzle - tip behaviour when unsticking from bed or similar, so it does that point again, until it gets cleaner reading, or it takes average value.
Publié : 10/08/2025 8:11 am
I have noticed this behavior as well on the Core One. I did not see this on the MK4. I suspect its a difference in firmware.
Publié : 10/08/2025 3:08 pm
