Link down Prusa Core one+
RMC_33
(@rmc_33)
Hello,
I am currently setting up my small garage print lab, and my Core 1+/w MMU will not fit in my home office anymore. Unfortunately, it has never wanted to connect to wifi (even when it was a MK4S) which was not an issue since it lived right next to my CAD box. I am hoping to use Prusa connect on it, but sadly it will not even connect to wifi. My other two Prusa machines (Core 1L and XL) connect without issue. I can see my C1+ on the network, but it always has shown as Link down.
I am assuming I have a bad wifi module but curious if I am missing something.
Posted : 19/03/2026 8:56 pm
RE: Link down Prusa Core one+
Try reregistering your printer with PrusaConnect. If your printer is on the network and has an IP address assigned then it's probably not an issue with the WiFi. As a test, does it work with PrusaLink?
Posted : 20/03/2026 8:51 pm
RMC_33
(@rmc_33)
Turns out it was a bad update at some point, which caused the machine to not be able to connect to my home network.
hard reset fixed it all~
This post was modified 2 months ago by RMC_33
Posted : 20/03/2026 11:19 pm
