LED barre: how to make a growing left to right LED while print completes?
Scott
(@scott-18)
Hi!
As said on title, does anyone know how to make the LED growing from left to right accordingly to the completion of the print?
That should be very nice to quickly see how the print is going!
Thanks a lot!
Napsal : 11/04/2025 11:44 am
Staldy
(@staldy)
RE: LED barre: how to make a growing left to right LED while print completes?
Or how about a red light sweeping left to right like KITT (Knight Rider) or a Cylon eye (Battlestar Galactica), depending on which classic show you grew up with, haha!
Napsal : 11/04/2025 12:19 pm
3 lidem se líbí
Scott
(@scott-18)
Haha, if there is a way to modify the sequence I guess we could make anything we want, but we have to know hoow to change it first!
Napsal : 11/04/2025 5:09 pm
1 lidem se líbí
Flora
(@flora)
None of this will be possible with the original LED strip. It is a regular analog RGB strip, where all the diodes are controlled by the same signal (PWM).
Napsal : 15/04/2025 12:25 pm
Posted by: @flora
I don't think that is correct. It's a strip of WS2812 LEDs, which are individually addressable via a daisy-chained serial data link.
But to my knowledge there are no provisions in the firmware for controlling them individually. Prusa's take is that you already get a "vertical progress bar" as the print bed moves down over time.
Napsal : 15/04/2025 1:01 pm
Posted by: @jurgen-7
Sorry, I was wrong there. Was really sure I had seen them labeled as WS2812 in the schematic, but they are not. There are separate PWM lines for R/G/B/W intensity, which will go to all LEDs in parallel.
Napsal : 15/04/2025 2:28 pm
1 lidem se líbí
Flora
(@flora)
50 individually controlled points.
As soon as I get the proper connectors and make the control from GCODE, I will post a more detailed description.
This post was modified před 1 year by Flora
Napsal : 06/05/2025 7:13 pm
2 lidem se líbí
Posted by: @flora
And the best thing: As long as you keep the LEDs flashing that, VFAs no longer matter at all! 👍 😉
Napsal : 06/05/2025 7:32 pm
1 lidem se líbí
Flora
(@flora)
For a good start: Core One Progress Bar
Napsal : 10/05/2025 9:07 pm
2 lidem se líbí
