Is there a way to set the number of perimeters for a part different than the perimeters for the main object?
Augendoc
(@augendoc)
I am trying to embed debased text into the bottom of a part (the bottom is the surface in contact with the build plate). The main object I want three perimeters. The text I want to have only one perimeter. Is there a way to do this?
Publié : 26/01/2026 4:11 pm
Walter Layher
(@walter-layher)
Use the search function in PrusaSlicer to search for the parameter "Only one perimeter on first layer". If you need more than the first layer, you can use a height modifier.
Publié : 26/01/2026 4:18 pm
RE: Is there a way to set the number of perimeters for a part different than the perimeters for the main object?
Right click on the text object in the right side pane, Add Settings -> Layers and Perimeters. In the pop-up box select the attributes you want to change.
Publié : 26/01/2026 4:22 pm
1 personnes ont aimé
