Input shaper values - FW 6.5.3
stevo1957
(@stevo1957)
I just updated to the final version of 6.5.3 (from the RC release).
Default values for input shaper are X - MZV 60 hz and Y - MZV 48 hz.
I ran calibration with the accelerometer and get values of X - MZV 38 hz and Y - MZV 41 hz, which I have saved.
The X value specifically is quite a variance to the default value. Is this normal to see such large differences to the default position?
Opublikowany : 24/03/2026 12:36 pm
jan.d.slay
(@jan-d-slay)
RE: Input shaper values - FW 6.5.3
At this point, it would also be a good idea to post your issue on GitHub ( https://github.com/prusa3d/Prusa-Firmware-Buddy/issues). You could do so here in the forum as well, but on GitHub, Prusa can forward it as an internal ticket if your information turns out to be important.
Opublikowany : 24/03/2026 12:53 pm
mnentwig
(@mnentwig)
It would help if you could confirm that belts are tuned with the strobe tool, maybe also that the gantry is squared.
Opublikowany : 24/03/2026 1:14 pm
1 ludzie polubili
Also, is this a factory assembled printer or a kit? If a kit then there is no way the input shaper defaults are accurate.
Opublikowany : 24/03/2026 2:27 pm
