[Rozwiązany] I see excessive wear on my belts.
colemine
(@colemine)
I started the buddy cam install.  When I took off the top side panel I could see some excessive wear on the top edge of my belts.  Anyone else notice this on their machine?  I might have shrugged it off but I have not done a lot of printing. Where should I start to look around to see if and where there might be a problem?  Or is this normal wear?
Opublikowany : 11/07/2025 10:38 pm
colemine
(@colemine)
RE: I see excessive wear on my belts.
Never mind... I was informed this is normal for the wires to show intermittently on the top edge and this is not a sign of wear or a problem.  I will continue on.
Opublikowany : 11/07/2025 10:45 pm
2 ludzie polubili
