How to fix Z band and VFA artifacts?
plasticsuzy
(@plasticsuzy)
I am curious how to fix the z-band which is persistent across prints. Happens around 26mm. All objects shown in the photos are printed using PETG Anthracite Prusament. Self-assembled Core One, which has been running for a bit less than a year. Not using the printer much, but on bigger objects I noticed the thick z-band. Running latest firmware(6.5.3) and PrusaSlicer (2.9.4).
Another issue are the VFA artifacts, though less of an annoyance than the z-band. The belts are tuned using the built-in stroboscope belt tuner. Though I know this filament makes the vertical artifacts more present due to the shininess.
Posted : 14/05/2026 8:36 am
plasticsuzy
(@plasticsuzy)
New to this forum, did not know I could upload images with the post. Image above are hosted on Imgur, which seems to be blocked for some regions. Now with photos hosted on this forum.
This post was modified 19 hours ago by plasticsuzy
Posted : 14/05/2026 10:19 am
RE: How to fix Z band and VFA artifacts?
Thank you, I can see the images now!
Posted : 14/05/2026 11:08 am
