How to fix Z band and VFA artifacts?
plasticsuzy
(@plasticsuzy)
Mitglied
I am curious how to fix the z-band which is persistent across prints. Happens around 26mm. All objects shown in the photos are printed using PETG Anthracite Prusament. Self-assembled Core One, which has been running for a bit less than a year. Not using the printer much, but on bigger objects I noticed the thick z-band. Running latest firmware(6.5.3) and PrusaSlicer (2.9.4).
Another issue are the VFA artifacts, though less of an annoyance than the z-band. The belts are tuned using the built-in stroboscope belt tuner. Though I know this filament makes the vertical artifacts more present due to the shininess.
Veröffentlicht : 14/05/2026 8:36 am
plasticsuzy
(@plasticsuzy)
Mitglied
New to this forum, did not know I could upload images with the post. Image above are hosted on Imgur, which seems to be blocked for some regions. Now with photos hosted on this forum.
Diese r Beitrag wurde geändert Vor 19 hours von plasticsuzy
Veröffentlicht : 14/05/2026 10:19 am
RE: How to fix Z band and VFA artifacts?
Thank you, I can see the images now!
Veröffentlicht : 14/05/2026 11:08 am
