Hardened Nozzle Setting
I can't find the hardened nozzle setting in the Core One Plus menu. I upgraded from a MK4S and remember there used to be a setting for it, I can't find it in the Core One menu. Is there one and if so where is it? I have yet to print with a filament thats needs it and from what I remember in the MK4S it would prompt you if it was not set. Thanks
Best Answer by andhson:
I am not at the printer but it should be in the same menu as the nozzle diameter setting, as I recall hardware->printhead->hardened nozzle on/off.
RE: Hardened Nozzle Setting
/Anders
Settings -> Hardware -> Printhead -> Nozzle Hardened
I found it,thanks!
