Gantry resonant mode and VFA artifacts
Page 4 / 4
jan.d.slay
(@jan-d-slay)
The Printables headline talks about "Replacing the linear bearings on the MK4S", which I found a bit confusing. Is that meant to refer back to an already proven solution in the MK4S? Still it might be better to mention the Core One explicitly right up there.
Hello, Jürgen. Thank you for pointing that out! I have corrected it—my hand was quicker than my brain could check it. 🙂
Interesting! I might (attempt to) print these out of POM. If that doesn't work, I also have a roll of Igus i150 I haven't found a use for yet.
That would be very interesting for a comparison.
Would PC or nylon also work in this case?
Publié : 15/02/2026 4:49 pm
Huggypanda
(@huggypanda)
RE: Gantry resonant mode and VFA artifacts
Awesome!  What is that bearing material, delrin?
Posted by: @jan-d-slay
Hello everyone.
I have now read various topics in the forum and on the Internet and have installed a plain bearing in the Y-axis.
I personally find the result impressive.
https://www.printables.com/model/1602328-prusa-core-one-resonance-noise-eliminated-with-sli
Now I'm going to take a VFA test.
Publié : 15/02/2026 5:21 pm
Huggypanda
(@huggypanda)
I've been working with prusa support in parallel to see if they had any suggestions.  They sent me a test print of a 30mm cube with perimeters at ~55mm/s and of course it printed perfectly, so they closed the ticket saying:
"the problem is caused by manual speed adjustment, so I recommend sticking to default print presets to achieve optimal results."
I've been working with prusa support in parallel to see if they had any suggestions.  They had me do a test print of a 30mm cube with perimeters at ~55mm/s and of course it printed perfectly, so they closed the ticket saying:
... as if that isn't the first thing I tried.  Oh well.  Guess we're on our own.
Publié : 17/02/2026 1:37 am
2 personnes ont aimé
Posted by: @huggypanda
It's not Delrin, from what I've been able to figure out, it's a nylon base modified with PTFE and solid lubricants.
Publié : 17/02/2026 2:44 am
jan.d.slay
(@jan-d-slay)
Yesterday, I conducted another VFA test with the two slide bearings.
PETG Black from Bambu Lab. I will have a glossy PETG available for testing again tomorrow. I believe it is still evident that the waves have not improved significantly.
As has already been mentioned here several times, the wave spacing is exactly the same as the tooth spacing of the GT2 pulley. Nice to see at the 30-degree test week.
My VFA test ranged from 50 to 150 mm/s in 10 mm/s increments.
Front and back - 90 degrees
Front and back - 0 degrees
Front and back - 30 degrees
Front - 60 degrees
Publié : 17/02/2026 7:29 am
1 personnes ont aimé
Conrad
(@conrad-2)
Just curious about something. On the factory linear bearings you removed, how are the ball races aligned? I think they're supposed to be at 45 degrees to the side forces, but not absolutely sure.
Publié : 17/02/2026 3:48 pm
jan.d.slay
(@jan-d-slay)
Posted by: @conrad-2
I'll take a look at the dismantled bearings.
Publié : 17/02/2026 3:49 pm
jan.d.slay
(@jan-d-slay)
Yes , they are!
Publié : 17/02/2026 7:40 pm
Page 4 / 4
