Files not removed from print queue after printing
Mike Daneman
(@mike-daneman)
This is probably not a Core One specific issue but has more to do with Prusa Connect, but my CoreOne+ is the first Prusa printer I have that uses Prusa Connect.  I'm constantly seeing that after I upload a file to the print queue, then print the file, that file stays in the queue and doesn't get automatically removed. I then have to manually remove it from the queue. I'm not sure if this happens every time, but it seems to happen a lot.  Has anyone else had this problem.  Is there a setting or something to make the files automatically get deleted from the queue after they finish printing?
Thanks.
Publié : 26/02/2026 6:22 am
RE: Files not removed from print queue after printing
I know it doesn't help fix the issue but I've never seen a file got "stuck" in the print queue. All I can think of is, after uploading a file to the queue, do you print it from the queue (setting printer as "ready") or do you use the regular print command from the uploaded file? In which case, the queued entry will still be there.
Publié : 26/02/2026 3:14 pm
Mike Daneman
(@mike-daneman)
Thanks. I typically set the printer to "Ready" to trigger the next file from the queue. Since it doesn't always happen, I'll look more closely into whether doing that vs. hitting the "print" button on the printer, or anything else makes a difference.
Publié : 26/02/2026 7:01 pm
Mike Daneman
(@mike-daneman)
I think I figured out the issue. When you add a file to the start of queue through Prusa Connect, the Core One displays a screen with this file and a “Print” button. If you hit the print button, the file will print, but will not get removed from the queue afterward. I found other people reporting the same issue. So this seems like a bug. Hopefully Prusa is aware of this and will fix it soon.
Publié : 14/03/2026 9:50 pm
1 personnes ont aimé
Bram
 Bram
(@bram-2)
Membre
I encountered the same issue and did not see this reported yet so I created https://github.com/prusa3d/PrusaSlicer/issues/15338 . Feel free to vote/follow that issue.
Publié : 07/04/2026 2:06 pm
