Error name: Filament runout. Using E-sun filament
Martin S.
(@martin-s-3)
Used plenty of this filament and prusament with my Core one. and never had this issue.
After i let it change the filament, ill just put the filament back through the loading process it instantly starts printing.
Never seen this issue, this Core one is used at a business location and used every day since it was new.
Could it be a damaged sensor ? Its just wierd this suddently happened when i switched from Prusament PLA til E-sun PLA.
This is the exact filament, not that it should matter https://www.esun3d.com/cmyk-product/
this is the error code that followed.
https://help.prusa3d.com/article/filament-runout-31829-core-one-17829-xl-26829-mk4s-13829-mk4-27829-mk3-9s-21829-mk3-9-28829-mk3-5s-23829-mk3-5-12829-mini_916077?_gl=1*irtva3*_gcl_au*MTQ4MTc5NjcyOS4xNzU0MzAyODgz*_ga*NDI1ODExMTc3LjE3NDU4NDg2NzE.*_ga_3HK7B7RT5V*czE3NTQ4OTg4MzMkbzExMiRnMSR0MTc1NDg5OTA5MiRqNjAkbDAkaDA.
Napsal : 11/08/2025 8:15 am
