enclosure illumination issue with the AFS system
[Risolto] enclosure illumination issue with the AFS system
multirep
(@multirep)
Hi all,
I've just installed the AFS (advanced filtration system) on my core one. I used the Prusa  one from my MK4s enclosure and a mount found on printables. The fan wire plugs directly on the FAN3 socket on the motherboard.
Since I've installed this, I noticed that it disable the light dimming function in the enclosure. No matter how, the led always stay a 100% brightness.
Does anybody here experiences the same issue?
Is there somewhere to report that bug?
Thanks!
Postato : 21/06/2025 1:20 pm
RE: enclosure illumination issue with the AFS system
Could it be something unrelated? Maybe the door switch not properly closing, or dithering between open and closed position?
Postato : 21/06/2025 3:29 pm
1 persone hanno apprezzato
multirep
(@multirep)
OMG! You are completely right! My door switch way not anymore set correctly, for an unknown reason. Once set up correctly, the dimming function worked again as expected. Nothing in relation with the AFS. Thanks again for pointing that out.
It's strange that the support dosent oriented me in this direction!
Posted by: @jurgen-7
Postato : 22/06/2025 10:42 am
2 persone hanno apprezzato
