Enclosure fans not turning on? Have advanced filtration on as well
I didn't see any answers looking around, I have the advanced filtration system which I can feel the fan blowing air. But the 2 enclosure fans with the temp sensor between them have never turned on. I've printed PLA and PETG so far, and even when the enclosure shows the temps higher than what it wants I have never seen the fans turn on. I assume they are there to help regulate the temperature of the enclosure. Is this intended or do I have an issue? Printer is working great otherwise.
Opublikowany : 02/08/2025 2:40 pm
RE: Enclosure fans not turning on? Have advanced filtration on as well
Enabling the Advanced Filtration system disables the internal fans. Given the resistance of the filter, those fans wouldn't do very much to push air outwards.
Opublikowany : 02/08/2025 11:41 pm
