Enable SSH to fix CORS issues for Prusa Link
joflogab
(@joflogab)
Utenti
Hi Everybody,
I recently acquired my first Prusa - a Core One+. Very happy with it so far!
But I want to create a custom web dashboard, relying on the Prusa Link API. However, I face CORS errors:
Access to fetch at 'http://192.168.1.37/api/v1/status' from origin 'http://192.168.1.31' has been blocked by CORS policy: No 'Access-Control-Allow-Origin' header is present on the requested resource.
I found out that I had to allow CORS origin, as discussed here:
https://github.com/prusa3d/Prusa-Link-Web/issues/391
To do so, I have to SSH in the Core One, but it's not possible. So I wanted to enable SSH as described here:
https://cdn.help.prusa3d.com/article/how-to-connect-to-rpi-via-ssh_658030
But the Core One doesn't run on a Raspberry Pi, and I can't find any SD card on the xBuddy card!
How can I do that?
thanks!!
Florent
Postato : 16/01/2026 8:01 am
You can't do this on a CoreOne. The Core One doesn't run a Unix operating system so you can't run a shell on it.
If you want to create something custom, I would suggest investigating OctoPrint which runs on a RaspberryPi connected to the USB-C serial interface on the printer.
PrusaLink API is baked into the firmware. There is no easy way to configure it without creating a custom firmware image.
Postato : 16/01/2026 5:27 pm
joflogab
(@joflogab)
Utenti
RE: Enable SSH to fix CORS issues for Prusa Link
Oh ok that's a bummer; I didn't know that, thanks!
Yeah, going with Octoprint may be an option, but then we "lose" the ability to use the LCD screen which is not ideal.
I've tried to setup a reverse proxy but it fails to authenticate against prusa links for now.
I'll continue my investigations!
Thanks
Florent
Postato : 17/01/2026 8:00 pm
Posted by: @joflogab
Octoprint is simply a serial host. It doesn't take over the printer. You won't lose the screen UI, PrusaLink, PrusaConnect. They are still available.
Postato : 18/01/2026 12:08 am
