Door deform when printing ABS (50°C+ enclosure temperature)
ron-f
(@ron-f)
First print and first little annoyance, my door deform when printing ABS (50°C+ enclosure temperature). I have to add some blue tape to keep the door closed. Except that I'm very pleased with that printer.
For now, for convenience, I disabled the door sensor.
I noticed:
  • There is not double side tape all along the door and its handle. I will add some on the two upper and lower part of the orange handle.
  • Deformation create more strength than the magnet, then the door keeps a bit open. I will try see how I can make the magnet closer to the steel handle or to change the magnet to a stronger one.
Best Answer by ron-f:
Not so easy to remove the original tape. I had to soften the tape with a small 300W airgun and then scrap it with a plastic scraper. Final step was to remove the tape residues with some what is called "Essence F" in French (Essence F — Wikipédia).
I set a new tape all along, pushed the handle against the plastic door edge and rotated it against the tape.
Now I have a quite perfect warm sealing. Second photo taken with chamber temperature being 58°C.
Postato : 12/03/2025 4:47 pm
Biomech
(@biomech)
RE: Door deform when printing ABS (50°C+ enclosure temperature)
Contact support for replacement door. It should not deform like that. Mine stays perfectly flat even at 55°C in chamber.
Postato : 12/03/2025 9:49 pm
1 persone hanno apprezzato
ron-f
(@ron-f)
Do you have tape all along the orange handle?
Mine stays flat except at high temp.
Postato : 12/03/2025 10:33 pm
tomtim
(@tomtim)
Utenti
I must use screws for the orange handle.. .there are 2 holes for the black clips, but the holes has the black tape over it. I use two small screws and the door is in the right position and the tape is pressed and hold the handle in position.
The glue is not for the heat 50 degress aviable... that is to hot. Please install a screw or you have the handle in the hand..
Postato : 13/03/2025 5:39 am
ron-f
(@ron-f)
Although there is no play in the holes (door/hinge and hinge/chassis), I untightened the screws, pushed the door against the hinges, tightened the screws. It is better now. I suspect the handle had difficulties to get closer to the magnets due to the chassis.
Next step, I think I will change the position of the handle a little bit, more to the inside. That should have two advantages:
  • It will move the handle away from the external angle of the chassis that avoid it to get closer to the magnets.
  • There will be less room for the door plate to deform.
Postato : 13/03/2025 11:18 pm
stoneymonster
(@stoneymonster)
Utenti
I’m having the same issue with a chamber temp of just 33ºC. I’m not quite following the fix here, just add more double stick tape? Or find some fitting screws for the unpopulated holes in the door/handle?
Postato : 16/03/2025 2:03 am
Cloud1983
(@cloud1983)
Why fiddle around with a new printer yourself? Contact support and have it replaced and that's that. This should not happen.
Posted by: @ron
Postato : 16/03/2025 4:28 pm
Posted by: @cloud1983
If a crooked door is the only problem that particular printer has, I would also be inclined to keep the printer and adjust the door myself. Who knows what problems a replacement unit might have? Noisy operation, pronounced VFAs, skewed gantry, unreliable Z homing etc. have each been reported by multiple users. All of these affect reliability and/or print quality, and are much more difficult to troubleshoot than a bent door.
Postato : 16/03/2025 6:29 pm
Chocki
(@chocki)
Just checked mine and the orange handle is tight against the edge of the acrylic, I think in your case it has been stuck on too far out, so when the door expands it is too big for the recess and pops out, there is a gap between the recess and the rounded end of the handle on my door, small but definitely there.
Postato : 17/03/2025 2:11 pm
2 persone hanno apprezzato
ron-f
(@ron-f)
I contact the support only in last resort and prefer to deal simple things myself. I know how slow it can be to be in touch with the support.
I removed the handle. The tape was then ripped. I need to print a plastic scrapper to remove it completely. I have double sided tape in stock to stick the handle back.
It won't cost anybody.
I may contact the support for them to improve their assembly process.
Postato : 18/03/2025 8:08 am
huskyte
(@huskyte)
Need to check on my Cores. They all do ASA/ABS/PCCF exclusively and I taped the enclosure to have it above 50 °C all the time. I haven't seen the effect yet, but I will check when I am in the farm next time
Postato : 20/03/2025 8:02 am
ron-f
(@ron-f)
Postato : 21/03/2025 5:53 pm
