Detailed changes made by the firmware Speed setting
ronguest
(@ronguest)
I recently used the firmware Speed adjustment during a print which was very handy. But it leaves me wondering what changes that setting makes in the context of PrusaSlicer. E.g. if I set 90% speed using the knob what would be the corresponding changes in the details of PrusaSlicer?
Opublikowany : 05/01/2026 1:56 pm
Girak
(@girak)
RE: Detailed changes made by the firmware Speed setting
I assumed it throttled all speeds by the set amount. For example, if you set your speed to 90%, then all preset speeds are dialed back by 10% (bridging, perimeters, infill, etc.). It would be silly and counterintuitive if it just changed the one preset speed.
You could do a quick check. Change it to 90% and see if the remaining print time is increased exactly by 10%
Opublikowany : 06/01/2026 7:58 pm
