Core One - Please Open Idler and remove filament
Pheo
 Pheo
(@pheo)
My Core One ran out of filament and I got this message.  "Please open idler and remove filament manually". Not knowing how to open the idler I thought a quick google and there would be a helpful image or video.  Several attempts later and I give in.  If I had a Mk3 or 4 there would be no problem but I have been unable to find anything that tells me how to open the idler.  Can anyone point me at an image or video?
Postato : 05/10/2025 9:04 pm
RE: Core One - Please Open Idler and remove filament
To open the idler lift up the idler latch #1, then pull out idler lever #2. Remove the Bowden tube by pressing down on the black ring. You should be about to pull out the stuck filament.
Postato : 05/10/2025 11:24 pm
It's almost identical to the MK4.
Here is an illustration showing the idler open with the catch raised - lift the catch and your idler will open similarly.
https://help.prusa3d.com/guide/6-nextruder-assembly_849034#850542
Postato : 05/10/2025 11:51 pm
