RE: Core One crash/restart
On two occasions my Core One has restarted when I am reinstalling the print sheet. Is this happening to others and does anyone have a solution.
Try turning off the door sensor in the firmware under: Settings -> Hardware -> Door Sensor
Some people mention static discharge, could this be your case?
Loving the learning curve!
That's a new one to me, but it sounds like you also might be generating some static electricity that would be better off elsewhere. Try grounding yourself while holding the build plate before you touch it to the print bed.
To find a convenient ground in the CORE One itself, use your multimeter to look for continuity between any of the 8 socket head cap screws around the Z axis rods at the front bottom. If you measure continuity (< a couple ohms) between any two of them, those two are very likely electrically connected to the sheet metal frame which should be fairly well grounded (assuming correct assembly). I found 3 with continuity in my kit-built unit and could presumably ground myself by touching them... if I could remember which ones they were 🙂 . The techniques described in this thread for grounding the X/Y motor screws (scratching off the powder coat, star washers) should work down there, too, to get more or more convenient screws grounded.
There's also an accessible ground point on the LCD board accessible if you tilt the control panel forward. With the printer switched off of course, I was able to take about an 9"/200mm length of 30AWG (0.05mm2) hookup wire, strip off 6"/150mm from one end and wrap that tightly around the crimped part of the connector. (Easier if you temporarily pull off that grounding connector, but don't lose it in the base!) Then I removed about 1"/25mm of insulation from the other end and routed the wire up behind the magnetically attached front piece so you can easily touch it at the bottom of the enclosure to ground yourself and hopefully remove excess static from the flex plate you're holding.
This picture should give you an idea of what I did...
...but I haven't had the problem you describe, so YMMV.
It would presumably be bad for the electronics if little bits of stray wire came loose around the display LCD electronics, so if you think this might help you, you might add a bit of electrical tape or even heat-shrink tubing around that added connection.
There are at least two causes of crashes. The first is static building up on the x-motor belt which discharges through the door sensor switch. Grounding the two motor casings will fix this. The other (which I never experienced) was some people experienced crashes opening the door. This was mitigated through turning off the door sensor.
Let me add a possible 3rd one: if the OP was walking on a surface that loaded him with static and he touched the printer when installing the plate... zzap! Same effect as the motor one build with the charge coming in from outside. I managed to do this once on my mk4s ... after that, especially on dry winter days, touching some grounded object before the printer became routine...
I bought some star washers off amazon and they worked perfectly. I didn't even scratch off any coating by hand. Just added a washer to 1 screw on the x and y motor. I didn't even have to take off any panels. Easy peezy. No issues since and I've done a handful more prints including ones that previously crashed.
Here are the exact lock washers I bought:
METALLIXITY Internal Tooth Washers (M3x6mm) 100Pcs, 304 Stainless Steel Internal Serrated Lock Washer
My core one started to crash and restart repeatedly every couple of minutes at 60% of a big print that takes almost all the X-axis. Found this thread and first I tried with alligator clips to ground just the X and Y motors. Continued the print and it didn't crash anymore after 30 min but unfortunately the print has lifted from the bed.
I used a multimeter to check for ground on the motors. X and Y motors are not grounded because the mounting screw doesn't make any contact with bare metal on the gantry. The three Z motors are sitting on an adapter piece between so grounding the mounting screws on top side doesn't work.
I have now proceeded to open up the panels and added toothed washers after sanding away some of the coating right at the motor screws. X and Y-axis should be now grounded.
The Z-axis 3 motors was a bit trickier to ground since they have an adapter in between. I had to do it on the bottom side of the printer and tried to "snap" a terminal connector between the motor screw and underside of the bottom plate. The other end of the cable just screwed with a toothed washer into one of the unused holes on one of the bottom brackets.
I will do another 10h big print which was crashing consistently. Hopefully this grounding was the problem.
I've had same issues with crashing/restarts lately. It could crash 5-8 times during 1 hour print. Now performing first print after ground repair. What I did: took out one bolt that was holding X axis motor, grinded off powder coating with dremel and assembled back together. Checked that it has continious signal from x (and y) axis motors housing to ground pin in power outlet.
Will reply in few days how did it went.
If this text is getting smaller, it means your monitor is being carried away!
It looks like it helped. Already 5+ hours printing without any errors.
Thanks to prusa community👍
It is probably not necessary to ground the Z motors. They do not drive a belt (which is probably a key ingredient in the triboelectric charge buildup), and they move by much smaller distances.
Also, the Z motors are insulated in all off-the-shelf Core Ones and kits because, as you say, they are mounted on those plastic flex elements. Nevertheless, users have consistently reported that the crashes disappeared for them after merely ensuring that the X and Y motors are grounded.
Yeah, I figured it wouldn't do much grounding the Z-axes but hey, while I was at it already then might as well do them, too. It makes me feel better knowing they're now also grounded. 🙂
My big print went smoothly without any crashes. I think grounding was the problem.
Prusa should address this issue. Maybe add a few toothed washers and an extra instruction step while installing the motors.
