Core One crash/restart
Page 11 / 11
Teezer
(@teezer)
RE: Core One crash/restart
I had this issue as well. when the printer goes from rear right side to front left side, I notised that the left rear motor moves but the other one almost stay still, when the printer restarted like a power cut. Grounded the left rear motor, problem solved. I fastend a cabel on one screw that fastend the motor. and other side a random spot on the frame
Posted : 20/09/2025 6:42 pm
mownby1
(@mownby1)
I added the star washers to both my X and Y axis motor, verified I have continuity from the frame to each motor with a Fluke Voltmeter. I have been printing for over 10 days without the issue popping up.
Posted : 21/09/2025 12:43 am
mmmachnik
(@mmmachnik)
I had two prints fail this weekend with a ton of travel and crashing.  While I wait for my 3mm washers to arrive I cut a test lead up and that same print ran last night without issue. Seems like the answer. I’m going to set up my o-scope and try to measure this someday.
Posted : 21/09/2025 5:14 pm
Posted by: @mmmachnik
In my case I just scraped away some powder coating from around the screw hole. That was enough to get a decent ground connection.
Posted : 21/09/2025 9:35 pm
CtrlC-Root
(@ctrlc-root)
I ran into this issue and fixed it with star washers as well. What's odd to me is how the printer ran fine for months after assembly and then suddenly started crashing almost every time I ran a print. I did just change the filament spool before that but it was a new spool of the same material I had already been using. Maybe the belt tension has changed over time which somehow leads to this problem happening more often or earlier in a print with diagonal movements?
Posted : 22/09/2025 11:14 pm
n1l5
 n1l5
(@n1l5)
Same problem here: sudden blackout of the machine during print while performing diagonal movements. Grounding the motor solved the issue for me as well (see image for the dirty hack 😉
Problem can be replicated by printing a flat square covering almost the complete bed. Error occurs at the first layer. I also tested printing a small square at each corner at the same time to test whether the motion to the edges of the print bed cause any problems. No problems here.
Belt tension has been configured using the app. Worked for me and prints look awesome. Seems like the grounding really does the trick. Thanks a lot for sharing this solution!
Posted : 23/09/2025 9:11 pm
Page 11 / 11
