Core One changing nozzle diameter 0.4 -> 0.6 - what a pain!
Inbox
(@inbox)
So trying to improve my print speed by using a HF 0.6mm nozzle in my Core One. Core One is networked so Prusaslicer can upload code directly to it.
As a process it is convoluted and painful, I did search for some guidance and from my search you are basically on your own.
I am at the point of just binning the Core One in favour of a Bambu printer just for the simplicity, the Core One is proving to be a frustrating PITA.
Posted : 02/12/2025 12:15 pm
RE: Core One changing nozzle diameter 0.4 -> 0.6 - what a pain!
Posted by: @inbox
I do it all the time. Remove the silicon sock, loosen the thumb screws, unscrew the nozzle, replace it with other nozzle, tighten the screws, replace sock. Takes less than 1 minute.
Posted : 02/12/2025 10:16 pm
I guess it's just a rant but let's break it down into its components.
The physical aspect. As @hyiger explained, it's straightforward. Takes less than a minute.
Configuring PrusaSlicer. Now I can see how that can be frustrating.
First, you need to go to Configuration>Configuration Assistant>Prusa Research and add the Core One HF0.6 nozzle. Click Finish. You should now have the HF 0.6 nozzle under Printer>System Presets.
Next, you want to add that profile to your physical printer. Select your current physical printer. Click on the gear icon next to it and edit it. The key here is to discover the + sign next to the physical printer name. Click on it and select the HF 0.6 profile, which now gets added to the physical printer.
From there it's easy. Just swap nozzles and make sure you use the correct physical printer.
Could it be easier? Sure. I hope with PS 4.0 they rethink the inane approach to managing printer and print profiles.
Posted : 02/12/2025 11:44 pm
