Core One Buddy3d Camera...... anyone know of a way to change the default print head home position at the end of a print?
Rushman
(@rushman)
So the home position of the print head blocks the view of the finished print...... anyone know a simple way to change the head position at the end (I guess maybe modify the end gcode).  Image attached.
Veröffentlicht : 20/03/2025 4:35 pm
fuchsr
(@fuchsr)
Mitglied
RE: Core One Buddy3d Camera...... anyone know of a way to change the default print head home position at the end of a print?
Make sure you're in Expert user mode in Prusaslicer, go to Printers>Custom G-code>End G-code, and look for the line
G1 X242 Y-9 F10200 ; park
Change X position to something else that works better for the camera. X0, X10 etc.
Veröffentlicht : 20/03/2025 8:24 pm
Veröffentlicht : 20/03/2025 8:31 pm
Brian
(@brian-12)
Confusing that you 2 put the exact same thing word for word,  maybe your AI.
Veröffentlicht : 20/03/2025 9:38 pm
Rushman
(@rushman)
Lol
Veröffentlicht : 20/03/2025 9:41 pm
Not AI. It's my living in purgatory.
@fuchsr was the Prusa account I had for many years. Then one day, surprise, I can't log in. Blocked. Sounds like a thing that Support should be able to fix in a few minutes. Four weeks later, and the only solution was to create a new account (@foxrun3d) and migrate all my contents over. Then they were able to reset my old account but it's now showing as new member and requiring approval of all posts. Would be okay if I could just forget about it and never use it again. But that account gets me into all my non-forum Prusa stuff, orders, PrusaConnect, etc. At this point I need to use foxrun3d to log in to the forum and fuchsr to everything else. Now on top, the whole Prusa authentication system sucks big time. Logs me out several times each day. And the clincher is that more often than not clicking the login button randomly logs me in to one of my accounts automagically instead of offering me an option.
So I guess when I replied to this post originally I was logged in to my non-forum account, and then I copied and pasted it to my forum account thinking the other post would be deleted by moderators, but now there are two identical posts here. Oh well.
Sorry for the long explanation—this authentication system they're using is just such a disaster.
Veröffentlicht : 21/03/2025 12:02 am
LarGriff
(@largriff)
Sadly, neither account offered the correct info.  😉  The Y axis is the one that needs changing, not the X.  No offense.  As a dyslexic, I make those mistakes all the time.
Posted by: @foxrun3d
Prusa MK4S/MMU3
Bambu P2S/AMS2Pro
Veröffentlicht : 21/03/2025 1:40 pm
Rushman
(@rushman)
Yeah, I guess I was hoping there was a magical on-printer setting I was missing so I wouldn't have to rebuild my gcode.  I have a few things that I print all the time.  Not that big a deal.  Thanks!
For those that find it in the future, here is what worked for me:
G1 X242 Y220 F10200 ; park
Posted by: @largriff
Veröffentlicht : 21/03/2025 1:56 pm
EvoDesigns
(@evodesigns)
Mitglied
I got a new phone last year and lost my 2FA with it. I was locked out of my old prusa account and they never responded to me when I needed assistance retrieving it. My XL, MK3.5, Mini+ were all on there, warranty ran out so it doesn't matter but if I need help and they want to cross reference the serial number, I won't be able to verify it. Lol
Veröffentlicht : 21/03/2025 3:01 pm
Rushman
(@rushman)
So for whatever reason this still parks up front.  I've saved the edited profile, I've made sure I'm selecting it when I slice..... any help would be appreciated.
{if layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+1, max_print_height)} F720 ; Move print head up{endif}
G1 E-1 F2400 ; additional retraction
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
M141 S0 ; disable chamber control
M107 ; turn off fan
G4 ; wait
M572 S0 ; reset PA
M84 X Y E ; disable motors
; max_layer_z = [max_layer_z]
Veröffentlicht : 21/03/2025 6:15 pm
critical_limit
(@critical_limit)
Same here. You can see the Head is going to the new position, but half a second later it is going back to the front right. No Idea how to solve that behavior
Veröffentlicht : 22/03/2025 6:14 pm
tomtim
(@tomtim)
Mitglied
same problem. my camera look on the printhead not on the bed after the print 🙁 i make the same entry...
Veröffentlicht : 23/03/2025 3:03 pm
Michi
(@michi)
The Problem is fixed with Firmware 6.3.1 and the newest CORE One Profiles in PrusaSlicer.
"Park printhead in the back after print
Based on user feedback, the printer now parks the printhead in the back after a print and during pauses to avoid obstructing the Buddy3D Camera's view.
For filament changes, the printhead still parks in the front for easier access. Homing also remains at the front due to the sheet detection process."
Diese r Beitrag wurde geändert Vor 11 months von Michi
Veröffentlicht : 04/04/2025 11:17 pm
