CORE One - Annoying sounds
Matthias
(@matthias-14)
Miembro
Hello,
can someone tell me where the annoying squeaking sound is coming from (direct at the beginning of the video)? I have already checked the belt tension and greased the rods.
https://www.youtube.com/shorts/ut5o62dUgaU
The rattling sound is definitely caused by printing infill.
So far I have printed without any problems, without these noises. It started today.
Este debate ha sido modificado el hace 3 months por Matthias
Respondido : 19/06/2025 7:24 pm
2 les gusta
BulletBuck
(@bulletbuck)
Miembro
It almost seems like the C1 hits a weird resonance at the same spot on each layer but doesn't happen every spot on each pass so just at a certin point the sound t happens every few moments,  but to me sounds like a high pitch vibration sound hard to explain
Esta publicación ha sido modificada el hace 3 months por BulletBuck
Respondido : 19/06/2025 11:53 pm
Scott
(@scott-18)
RE: CORE One - Annoying sounds
There are already several topics about those noise issues:
Here, here and here
It's resonance noises at 80mm/s (when printing inner walls in structural speed profile).
Respondido : 20/06/2025 5:58 am
2 les gusta
Matthias
(@matthias-14)
Miembro
Thanks for the reply and I have now actually printed with the STRUCTURAL profile. I will check it out.
I am currently printing with the 0.2mm SPEED @COREONE HF0.4 profile. I have the same sounds.
Respondido : 20/06/2025 10:08 am
Raaz
 Raaz
(@raaz-2)
Mhh, I sadly don't really hear the squeaking. Can you record another video, where it's somewhere in the middle of the recording?
The rattle during the infill is simply the acceleration of the Core One during the small moves. Try switching to stealth mode, which simply uses slower maximum speeds (160 vs 350 mm/s) and way lower acceleration values.
The steady resonance noise during the long Y-axis lines should be the 80 mm/s resonance, Scott linked you to.
So from my view, only the squeaking stays a mistery. But to really analyse it, I would need to download your video, cut the first second into a loop etc. So please just record another video and don't make it a short (if possible).
Respondido : 20/06/2025 2:23 pm
Matthias
(@matthias-14)
Miembro
I will try it.
Respondido : 20/06/2025 3:49 pm
Matthias
(@matthias-14)
Miembro
I did this and it worked for me.
Respondido : 22/06/2025 12:45 pm
ideidrees9
(@ideidrees9)
Miembro
I tried last year and it works fine,
Now I am using its updated version
Esta publicación ha sido modificada el hace 1 week por ideidrees9
Respondido : 16/09/2025 12:14 pm
